rickeolis's Avatar
Porsche Crest Timing chain cover: Oil?
I have removed the muffler and sheet metal to expose my timing chain covers so that I can inspect to see why I am hearing the well known noise that will probably tell me that I need to replace my chains.
My question is: Is there going to be a lot of oil that comes out if I pull off the left cover without draining the oil first? Or is there just a small amount of residual oil that will come out?
Please answer only if you really know, thanks.
By the way, it's a '69 911T with a carb'd 2.0 liter. I love how simple these early cars were designed!
-Rickeolis-
1986 Corvette
Old 11-09-2002, 03:12 PM
Early_S_Man's Avatar
Porsche Crest
Very little oil loss ... less than a cup for both sides, combined!
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 11-09-2002, 03:39 PM
rickeolis's Avatar
Porsche Crest Thanks-
That is what I suspected, thanks again Warren, you have helped me and a couple friends of mine out several times.
-Rickeolis-
1986 Corvette
Old 11-09-2002, 09:10 PM
Send a message via AIM to 82SC
during my PPI, there was a good splash of oil...
I'd let the engine cool and drain into the sump...and have a turkey roasting pan under the covers before you take it off...
good luck
Old 11-09-2002, 09:13 PM
rickeolis's Avatar
Porsche Crest
Do you guys think I will need new gaskets?
-Rickeolis-
1986 Corvette
Old 11-09-2002, 09:16 PM
A Quiet Boom's Avatar
Depends, what's your time worth when you have to take the covers of to fix the leaking old ones? Or what if the get torn during removal? Always replace used gaskets.
Email me about 911 exhaust stud repair tools, rsr911@neo.rr.com
1966 912 converted to 3.0 and IROC body SOLD unfortunately
1986 Ford F350 Crew Cab 7.3 IDI diesel, Banks Sidewinder turbo, ZF5 5spd, 4WD Dana 60 king pin front, DRW, pintle hook and receiver hitch, all steel flat bed with gooseneck hidden hitch. Awesome towing capacity!
Old 11-09-2002, 11:21 PM
