So to get to odometer to work accurately you would need the gears to me changed as above. If you were to just change the speedo dial/faceplate from the MPH/KMH faceplate to the KMH one would it still read OK as the needle will still be in the same place throughout its range?
I looked into doing what you want to and the answers I got were not very assuring and confusing. I ended up sending the speedo to North Hollywood. Took about 4 weeks and had the speedo overhauled and converted. They also reset the odo to read the same mileage but in Km. The indicator is a weird color because of the light, they repainted it the correct red and the speedo looks great.
http://forums.pelicanparts.com/uploa...1641073174.jpg |
I'd have to factor in the shipping cost from and to Australia Thanks, Frank |
I think I have a set of the conversion gears. If so, I can convert a working MPH speedo to Km including a new face, new gears, reset odometer, and restore needle and bezels for about $350.
BTW do you still do the AFR in the bottom of a Tacho? Cheers, Frank |
http://forums.pelicanparts.com/uploa...1641087389.jpg |
| All times are GMT -8. The time now is 03:10 PM. |
