'69T Speedo Cable Transmission leak
I'm restoring a '69T, and I have a significant transmission fluid leak out of the speedo cable seal. A search finds two threads on this topic, but no useful answers. I once saw a clever method for replacing the seal without dropping the tranny but can't find it now. Any help would be appreciated.
Thanks, Rich |
The seal is in the aluminum part that plugs into the trans. drain the oil and remove the whole speedo drive unit after removing the set-bolt, the take the angle drive off to get at the seal. Also an o-ring on the outside.
Thanks!
Thanks!
So apparently there is a seal between the angle drive and the aluminum part (see photo in post above).
Does anyone know what type of seal? |
For those who have the same problem or might have in the future, John of John Walker's Workshop answered my question via private mail:
"there's a radial seal in the aluminum piece and an o-ring around the aluminum part that seals it to the hole in the end cover. 999 113 036 50 and 999 701 084 50 respectively." Thanks, John! |
If you separate the two pieces, you will see the seal. What's that blue stuff?
Blue stuff is Swepco 201, which came pouring out on me when I yanked the assembly out! Good thing I had a rag handy to plug the opening. https://flic.kr/p/sm1p5W Last edited by 911T70; 06-15-2015 at 06:18 PM.. |
