thanks guys, still no nearer to deciding the best route
thinking it over juan, yes you can. i came across a couple of threads try a search "compressed air" "air compressor"
Rich ![]() '86 coupe "there you are" |
It is easy to rig a setup from a SCUBA tank. Use a SCUBA first stage regulator, it will be set to 150 psi already, add an inexpensive normal regulator or tune the SCUBA 1st stage down to the psi you need. 90 for most impact tools
The down side, unless you dive you will spend $$ for the set up $140 tank $200 or so for a 1st stage. The tank must get a visual inspection ($20)each year The next storage tank method is nitrogen. Buy or rent a tank Small oil less compressors with 2 to 4 gallon tanks Best method for really infrequent use, find a buddy that has the stuff
Green 912,
can you set the torque in these things then (the snapon cordless)??
You can’t set it in to a given torque such as 40 ft/lbs but you can regulate the power applied with the trigger. Air guns have a knob that gives 4 or so power settings that work by restricting the airflow. I have found that this setting will vary widely depending on the air pressure
thanks for clarifying
