I'm just telling you what is written on most cans of Freon: shake and turn upside down periodically. Those cans are under very high pressure. You won't have pure liquid escaping unless the pressures are zero in the can. They also might have a straw inside, like a spill proof baby bottle, so when you turn upside down you have no spillage. The agitation and direction change would help to ensure all contents are expelled uniformly. |
you can turn the can upside down to initially charge it into the hi side.
charging into the low side the can is always right side up. now, people do charge liquid into the low side. i have done it. i dotn make it practice to do it but i have. has a compressor been killed while doing it, probably not. has it been damaged but still works, probably not BUT, you never know. |
http://idqusa.com/instruction/arctic-freeze_2013 |
The OP asked how long it takes to run in a can of R134. I told him maybe 5 minutes or so. Anybody else been responsive to his question?
Thanks, Dave |
Yes one other offered an answer my question - 2-3 minutes. I have noticed that A/C threads often goes off track pretty quickly. I do appreciate you feedback! Wayne |
That's good Wayne. After 23 posts, I forgot.
Good luck, Dave |
"On the clock" A/C technicians often fine ways of doing things more quickly, things no DIY should do. Without the engine running, and with vacuum still in place, the technician opens both manifold valves and FLOODS the system with liquid refrigerant, no more than 80% by weight. Now the engine can be started and the system topped-off the same way as a DIY. There is also a note indicating sometimes use of the low side manifold valve being used, carefully, as an orifice, liquid in, gas out. |
With regard to charging systems with the can upright or inverted either way can be used. If I have a vacuum on the system I will purge the line going to the manifold gauges and charge the high pressure side with the can inverted charging only the high side with liquid and the compressor OFF.
Never under any circumstances charge the low pressure side with liquid with the compressor off even under a vacuum. The pistons in the compressor don't like liquid if any kind and will cause damage to the pistons - it's called hydraulic shock. Now once the system will not take any more refrigerant with the compressor off, close the high pressure side manifold gauge, start the engine and turn on the compressor. You can now finish charging the system with either the can upright or inverted on the low side. Now if you decide to charge the system with the can inverted you need to only crack open the manifold gauge valve on the low side ever so slightly and start charging. My gauges have a sight glass so I can monitor how much liquid is being charged into the system. I usually allow the sight glass to fill half way with liquid. By doing that the vacuum on the system is deep enough to cause the liquid to expand into a gas as it enters the compressor. The system can be charged faster by using this method and there is no chance of damaging the compressor as long as the low side charging valve is cracked open enough to allow a low volume of liquid to enter the system. The can will start to get cold as the system is charging sio you know the refeigerant is entering the system. One note of concern if you notice frost on the connection at the compressor you are allowing too much refrigerant to enter the system. Hope this will clear up the question regarding "inverted vs upright" charging methods. |
what is the outside temp. are there any porblesm with his system. is his engine running. it could take 5 minutes, it could take 20 minutes. |
when the system is empty you can charge on the hi side with liquid and the system off. you want to do an initial charge before you turn it on. liquid just tends to go in faster. the reason you "swirl" the can is so the refridgerant picks up heat from the outside of the can to raise the pressure. (thus the hot water). |
| All times are GMT -8. The time now is 12:37 PM. |
