Head Temp Sensor Location?
Trying to locate the head temp sensor to review before ordering replacement. Pelican Technical article says it's in the left rear wheel well. I can't find it, is this it?
Is this the connection? http://forums.pelicanparts.com/uploads/My Pictures2.jpg Is this it on the left and what's on the right? http://forums.pelicanparts.com/uploads/My Pictures3.jpg Also, this rubber connection is a little cracked, what is it and should I replace it? http://forums.pelicanparts.com/uploads/My Pictures1.jpg Thanks, JG |
the white plug in the upper photo leads to it. the sensor screws into the front of #3 head. it's under an oval piece of rubber with a wire coming out of it. remove the L/R wheel for access. do not overtighten the new one, as it may break off in the head. job rated: minor PITA, but gets easier as you do more, not that you will. use silicone spray on the rubber, especially the upper grommet that the three wires go thru.
1 Attachment(s)
Head temp sensor is in the drivers' side rear wheel well. Look for a white wire. Here's a pic.
The round sender (about the size of a "D" cell battery) to the right of the fan is the oil temp sender. |
| All times are GMT -8. The time now is 01:13 AM. |
