-   -   Had my injectors cleaned by MR Injector (http://forums.pelicanparts.com/porsche-911-technical-forum/870453-had-my-injectors-cleaned-mr-injector.html)
cabmandone 06-12-2015 07:04 PM
I recently sent my injectors in for cleaning. I did some reading and found two names that came up in a lot of threads. I chose MR Injector after reading a lot of comments. I haven't installed the injectors yet but I have to say they look very nice (new). One of the biggest complaints I read about others was that no paint was applied to the outside to protect them. Mine were nicely painted and individually wrapped or bagged in those heat seal bags and then all put in a larger heat seal bag. And possibly best of all they threw in 2 jolly ranchers, I mean.. who doesn't like those? I got a nice sheet showing before and after cleaning flow. None of mine were bad. The worst one was 61 and now all are 65. I'll try to post some after pics since I didn't take any before pics.
bugstrider 06-12-2015 09:49 PM
Interested to see the results
88911coupe 06-13-2015 07:17 AM
Good info, BTW, are there any telltale signs that injectors need to be treated?
Flat6pac 06-13-2015 09:23 AM
There is no signs that the cleaning is needed but for just over $100 you have that piece of mind..and you get the Jolly Ranchers..
Bruce
cabmandone 06-13-2015 06:32 PM
The main reason I had mine done is I have the engine torn down replacing head studs. I figured while I had it down I might as well get them cleaned.
Here are some pics of how they were packaged and how nice they looked after.
http://forums.pelicanparts.com/uploa...1434245286.jpghttp://forums.pelicanparts.com/uploa...1434245378.jpg
http://forums.pelicanparts.com/uploa...1434245525.jpg
cabmandone 06-13-2015 06:37 PM
I forgot to add the sheet he sent on flow before and after.
http://forums.pelicanparts.com/uploa...1434245792.jpg
winders 06-13-2015 06:59 PM
I just had the injectors in my race car cleaned. I chose R.C. Engineering because a friend had used them with good results and a local racing shop with a great reputation with fuel injected cars uses them for all their injector cleaning. Plus, their turn around time was fast and I was in a hurry.
I don't have the injectors back in hand. But I do have the test report.
Code:
                BEFORE                                AFTER
Inj.#      CC/Min        Pattern    Inj.#      CC/Min        Pattern
1          332.0          Fair        1          360.0          Excellent
2          347.0          Fair        2          367.0          Excellent
3          341.0          Fair        3          359.0          Excellent
4          341.0          Fair        4          362.0          Excellent
5          337.0          Fair        5          372.0          Excellent
6          349.0          Fair        6          360.0          Excellent
I race the car next weekend. I'll report back on how the injectors work.
cabmandone 06-13-2015 07:01 PM
Code:
                BEFORE                                AFTER
I forgot to mention turn around time. It took about 9 days total from ship to receive. The test will come when my engine is back in but since mine were pretty clean to begin with there probably isn't going to be much noticeable difference.
winders 06-13-2015 07:11 PM
When I say fast, R.C. Engineering quotes 24 hours at their shop. Total time depends on how you ship and how you want them to ship back.
cabmandone 06-13-2015 07:30 PM
Most of my time was spent in shipping. I went the USPS priority route. The injectors left my brother's place in VA on Tuesday 6/2 and by 6/5 I had an email stating my injectors had been serviced. Keep in mind, my time above included a weekend. I have no complaint with the turnaround time.
I'm curious, how much did it cost to get them done? My bill was $130 with the ship to costing $17 due to me placing a higher insurance value on the injectors in the event they got lost in transit. I figure if USPS screwed up, I'd get a new set of injectors rather than a rebuilt set.
winders 06-13-2015 08:10 PM
$24 per injector if the standard top/rail feed style injectors like yours or mine. Shipping rates depend on how fast you want the injectors back.
Ferrino 06-13-2015 08:34 PM
Great info. How long do they suggest between having them cleaned and running them on the engine? IIRC, they can tend to seize if you leave them too long?
Nick Triesch 06-13-2015 09:57 PM
Or just use Techron once in a while. If your car runs just fine, then the injectors do not need cleaning.
cabmandone 06-14-2015 04:27 AM
I've read a lot of threads on the topic of stuck injectors. My engine sat for over 5 years while the PO tried to build his car. I must have gotten lucky. As for how often to clean I say the best thing to do is use a little preventative maintenance and run some injector cleaner occasionally and make sure you put a fuel stabilizer in if you part it for the winter.
cabmandone 06-14-2015 04:30 AM
Okay, I paid $17 per injector plus shipping both ways. He used USPS priority on the send back. I'll bet your guy doesn't throw two Jolly Ranchers in the box :D
Dan J 06-14-2015 09:38 AM
Very important step when having the heads rebuilt
If you combine new,tight valve guides with a lean injector you have a disaster waiting to happen
There's many places to get it done. I use Marren because they're a mile from my shop
Cheap insurance especially when dealing with 30 year old injectors
winders 06-14-2015 10:38 AM
I didn't pick RC Engineering based on cost. I asked a local top notch race shop whose cars are almost all fuel injected what company he used to clean injectors. Then I did some research on the company. After that, it was an easy choice. The turnaround time was a bonus I was willing to pay for but did not have to.
winders 06-14-2015 10:40 AM
Dan J, I agree. There is a lot more to clean and proper functioning injectors than running Techron through them once in a while!
bugstrider 06-21-2015 07:11 PM
Does this apply to newer injectors only or would an older CIS system benefit as well?
Nick Triesch 06-21-2015 07:46 PM
Some of the very best on this site say Techron does the job. If your car runs great, why would you send them out ? If your car runs terrible and stumbles, send them out.
winders 06-21-2015 10:39 PM
Nick, whatever you say. But, it is kind of like working on you marriage AFTER it has failed.
