-   -   Puzzling Heater Question (http://forums.pelicanparts.com/porsche-911-technical-forum/87049-puzzling-heater-question.html)
Mark Howard 11-10-2002 12:22 PM
Hi guys. I've got a good one for you... My footwell heater blower fans on my '88 Carrera are acting really strange. When I pull the heater levers, they activate for about 3 seconds then quit. I thought it was time to lube the shafts and/or replace them, so I removed and tested them on a seperate power source....they run strong with no problem...put them back in...same thing, run for a few seconds then stop. I checked the fuses and the heater relay in the front...no problem. I used a test light on the power source for the fans, and I get power for just a few seconds, then power goes out, so I know it is not the fans.
The car has one of those goofy center switch dials to adjust the fan speed, but no matter what setting, power only lasts for a few seconds.
Anyone ever experienced this or any ideas on the source of the problem?
john walker's workshop 11-10-2002 01:04 PM
the engine mounted heater booster fan must first work for the kick panel fans to function. it's how the relay was designed. so see if it does.
Mark Howard 11-11-2002 08:18 AM
John - the rear blower works fine, runs strong.
Other thoughts?
