Have you thought about replacing the cat with a pre-muffler to reduce temps in the area?
BTW, after I did my AC I got about 39 degrees at the center vent while driving on an 80 degree day, black car. That was with the stock deck condenser, desert duty front condenser, serpentine evaporator in a sealed, insulated box, procooler and barrier hoses, on R12. I thought I was good until I ran across Kansas on a 95-degree day; the AC did absolutely nothing under that condition. Definitely needed more condenser. |
Regarding fans, I hooked it up to a power source and it pushed impressively, and I noted the polarity. I didn't note the direction it was spinning, nor can I even see it at this point! Will check when I get it all hooked up.
@CG, thanks for the encouragement. A larger fan would push more air, but in the process of getting everything to fit together I was glad I had a little wiggle room. Without those considerations, An 11" would have fit perfectly, 12" would have overhung the edge a bit. On the outboard side there is a little flange at the top that interferes. |
You should ask Dave (Wavey) about his wildlife encounter. For legal reasons he's always been a bit vague about how fast he was going. |
I'm not concerned too much about this but will observe pressures once I get it up and running. I already fabbed a simple heat shield that can mount on the bottom of the bracket if warranted |
What I'm finding so far is oil tends to pool in low spots throughout the system. |
Speaking of oil, when you add it to the condenser, do you simply pour it in both the suction and discharge ports, or what? I got very little out of it when I drained it. (Lots more from the front condenser and hose.)
Question for Ronnie: did you get you smuggler box insulation from a muffler shop? What is it, exactly? (I have insulation envy and must know details).
Nathan,
U'd be surprised in the difference of CFM between various brand's of fans. I'd suggest focusing on Spal or their closest competitors; avoid certain west Pacific imports; over the years we tested many. If you can fit a 12" with overlap, go for it. Remember that most of the 'muffin' or low profile fans all have approximately the same diameter motor case, that section of the fan does little: 3" dia = Area equals Pi times r times r or 7" sq of nothing. In terms of oil, once you have a fresh system running the oil become homogeneous in the system, it spreads through out. The primary traps are drier and evaporator. If you trying to add oil to a system you don't need to pour into the new component, you can put it in anywhere and within a few minutes of running the system it spreads out. A typical 911 system needs 5 to 6 oz in total . |
It's really nice stuff to work with - long fairly "thick" strands of fiberglass material, that packs very well into every nook and cranny, without flying all all over the place while doing so, and stays put. http://forums.pelicanparts.com/uploa...1434423270.jpg |
Thanks Ronnie, I really liked the look of this stuff in your install.
Nathan, I forgot to mention that the pictured bag is labeled 450 grams, and I used a whole bag and about a quarter or so of a second bag.
Thanks, and I can't say definitively what kind of a difference insulating around the evaporator housing made with regard to performance (I made several changes at the same time), but I did it primarily for the heck of it, and it makes sense to my limited intellect (right, Eric?!?!), but as you are aware, I have seriously cold a/c even in burnass TexASS, so maybe it helped . . . |
The insulation kit that came from Rennaire was an industrial HVAC product. I was a large sheet of heavy aluminum foil bonded to a thick, black insulating foam (1/8"?) with an adhesive back. It wrapped/molded around the evap box so it sealed air leaks and reflected ambient heat under the trunk lid. The evap box was then a pretty tight fit into the smuggler box, but there was some room left to cram in more insulation.
Anyone think of covering the interior of the smugglers box with a spray can of undercoating?
It appears to me that mounting a condenser near the engine/exhaust/catalyst as a first effort sometimes requires a second condenser to get the "job" done. Logically one would think that the first effort marketed/offered would/should be the front of the rear wheelwell. |
Isn't that an admission that the IR from the engine/exhaust/catalyst has some level of adverse effects? So what is your threshold? With our cars it is clear that every little bit of improvement to the A/C must/should be paid attention to, especially so when there is an obvious, virtually NO COST solution. So why Op to ignore this aspect..? Op purchased ($100 :):)) the 993 condenser from our sponsor, and custom building the required hoses, so no vendor is being "dissed" by suggesting a different mounting |
What % would be your guess..? |
If you want to do a little research on your own, you'll need to learn about the following: Radiative vs. conductive heat transfer. Emissivity. The temperature of the condenser at operating pressure. The surface temperature of a stainless steel catcon housing at steady-state engine operation. For grins, you can triple the operating temp of the catcon and plug the number in. The results will make you laugh out loud. |
The fact is, placing the condenser farther away from a >400 degree heat source improves the condenser efficiency. Run your car hard for long enough to bring the catalyst up to operating temperature, stop the engine, and then place your hand in the approximate area of the rear mounted condenser. Now repeat the procedure but place your hand in the approximate position of the ZIMS condenser. Think for minute, what would your opinion be had Porsche placed the 964/993 condenser in the rear of the wheelwell and an aftermarket supplier came up with a kit to move it to Porsche's actual choice? No market for the kit? Sure. |
Me, I'm waiting to make a quick observation once I get up and running, but I'm not really concerned. I doubt it's a problem, and it's easily fixed if it is. |
Another question. On what fittings do you use Nylog? I noticed the service port adapter seems to be a flare fitting. Should I use Nylog on the face of the flare? Or on the threads? Or not at all?
I've noted others recommend NOT using it on o-rings. |
Just picked up my '78 from there, on loan to my nephew for awhile. I doubt that Boise climate will be a challenge for your system even if there is degradation from the radiant heat. |
The box was a minor struggle to remove and replace, a little more so after the insulation was added. It was a nice snug fit on final reassembly. I'm going to search again for photos or posts from the project. The whole idea was to seal the evap box to prevent air leaks so as to get max efficiency from the fan, and also to insulate to keep the cold inside and to keep the underhood heat out. I'm sure you can deal with those issues separately; seal up the evap box, insulate the hell out of the smuggler's box and be sure the seal to the chassis is good. BTW, I had to replace my temp control, and feeding that capillary tube through the console and firewall and into the evap box was a M@+#&r#@%er. You get my drift. Lots of finesse required. Not sure if you're getting into that? Quote:
Hi Nathan,
I used lots of Nylog on my system. I think of it as a thread lubricant, so the surfaces can seat properly. I think it is made from a/c refrigerant oil, and becomes quite viscous. Within reason I don't think it has much of a downside, such as clogging your system. OTOH I think Griff assembles his stuff dry, but he's a pro with lots of experience. BTW, I really like your system, and IF my Wwested design does not perform well enough, yours will be my next step. I already have most of the parts and will just need one hose made. Thanks for sharing, Dave |
Regarding goo on threads and o'rings - I use a thin smear of silicone grease on all of the o-rings and a tiny dab of nickle anti-seize on all threaded connections. I always use a drop of oil on the flare portion of any flare fitting (don't have those in my a/c system, however).
Refrigeration Technologies: Products: Nylog Blue |
Oh look, my 134a showed up todayhttp://forums.pelicanparts.com/uploa...1434591675.jpg
| All times are GMT -8. The time now is 09:04 PM. |
