By the end of the day, I had all the miscellaneous bits and pieces in place and was able to return the car to the garage floor on her own wheels. Now I just need a high side service port adapter and I'm ready to charge.
Does anyone remember how much 134a Karl (discseven) put In his system?
87 Carrera Coupe Black on Black, H4 Headlights, Nurburgring Sticker |
Plus this resolves the fitment issue since the actual correct port rotates...
Karl put 26 oz exactly.
87 911 coupe, GP white, cashmere/black 64 Alfa Romeo Giulia TI - the violin 89 Peugeot 505 Turbowagon-other Pcar 67 912 coupe, white, sold 04 Audi Allroad 2.7T |
I did, but if you go back to the first few pages of this thread Charlie gives a tip on how not to. Having it out helped me visualize that space better, but putting it back in was a serious PITA. And I've done it before. somehow I managed to break both hoses that go to the vapor recovery pod just above the tank. Another trip to Napa and I was ok.
BTW, When the two hoses are routed over the bumper shock where there is a sort of channel in the body (might have come like this from the factory) road debris gets packed in there and promotes rust. Keep the channel clear so it can drain.
I had a ton of dirt packed up In that area, it's out now.
Banned
![]() ![]() PS - good deal about the fitting (even though you had it all along), and really sweet progress overall! PSS - I learned from Griff after doing it (when he saw this picture last year), that mummifying the expansion valve is not necessary, even though they often came that way from Porsche (like my original one did). Last edited by Ronnie's.930; 07-13-2015 at 08:54 PM.. |
Nathan, can you give me an idea of how much hose you used? Would 25 foot rolls of #6 and #8 be enough, with a single length of #10 as needed? I know every setup is different, but it'll give me an idea if 25 is far too much or far too little.
Mike Bradshaw 1980 911SC sunroof coupe, silver/black Putting the sick back into sycophant! |
That bottle of oil I sent you? Whatever is not in it is how much I put in my system. I didn't have the extra condenser, but the desert-duty front condenser and extra hose lengths for the procooler required a bit more.
Deceased: Black '88 Carrera Coupe, Steve Wong and Russell Berry chips, Dansk premuffler, custom MK GT3-style muffler, Magnecores. Al Reed 7 & 8 X 16 Fuchs. Full Elephant Racing suspension, 21/28 T-bars, Turbo tierods, bump steer kit, Bilstein Sports, BK strut bar. Ruf bumpers, 935 mirrors, Carrera 3.0 tail, DasSport bar. '11 BMW 328iX, '18 Nissan Frontier 4X4, '92 Acura NSX. |
Thank God for galvanizing.
I'm going to go back and check all my orders and get back to you... More to follow. I do have notes. If you have existing hoses, I highly recommend removing all of them and figure out everything you need and order it once. I spent a lot of time waiting for additional orders to come in, which was frustrating. Cheers, Nathan
Charging starting in 20 minutes!!!! By then the vac pump will have run 4 hours.
First attempt at charging was, unfortunately, unsuccessful.
Things were progressing ok, I think, then the o-ring on the binary pressure switch blew out. I did capture some P&T data OAT = 85F at beginning of test Static charge = 80 psi Before the big blowout, Hi = 250 psi Lo = 65 Vent T = 55F Charge weight = 17.2 oz Note: I didn't have the deck lid closed or a box fan blowing on the car. Next time... Will post pic of o-ring, not sure what to do about it.
![]() Argh. When I installed this switch, if I over tightened it, the o-ring would squish out the side. I'm not sure what else to do with it.
87 Carrera Coupe Black on Black, H4 Headlights, Nurburgring Sticker Last edited by NathanR; 07-19-2015 at 09:27 PM.. |
Banned
Nathan, does the boss (the hole) that the switch screws into have a groove in it to accept an O-ring? If not, what you see there is exactly what happens. I ran into that problem (no groove) with my home built setup, so used a tiny copper washer instead - worked perfectly.
If it does have a goove for the o-ring, and it is squishing out like that, then the o-ring must not be the correct size (either too large of a diameter, or to "thick"). |
I originally planned to delete the decklid condenser but changed my mind once I started. so I have some extra #8 hose but here are my original estimates Comp to R.Cond = 7' of #8 (I'm guessing I used roughly 5') R. Cond to F. Cond 11' of #6 F. cond to R/D 5' of #6 R/D to Evap 3'4" of #6 Evap to Comp 13' of #10
Where did you buy your fittings from? I have 12 fittings to buy, and have sourced them for anywhere from $35 to $85 (same fittings, often the same part number!). huge markups with some companies, which I'd be fine with if they had spectacular service as well. A/C Compressor and A C Compressor from AC Parts was by FAR the cheapest, but they might be crap service...
No groove for o ring. Copper washer sounds like a good idea. Hardware store item? Thanks a ton. I was out of ideas. Cheers, Nathan
