Bollweevil
OK fellow Middies - ?? on motor/transmission mounts
How are the concave disks aligned on your rear motor and transmission mounts ?
An earlier thread indicated they were changed in 1978. Quote:
Since changing the orientation I have noticed a weird rumble occasionally at low speeds but it never occurred to me that might be what is causing it? So how are the disks oriented on your car ??
Jack 74 911 Coupe 2.7L - K21 Option - S suspension |
Straight shooter
Concave not facing each other; I went with turbo rubber mounts as well. No rumbles.
With concave facing each other, the edge will be more prone to contacting metal on metal.
“Of the value traps, the most widespread and pernicious is value rigidity. This is an inability to revalue what one sees because of commitment to previous values. In motorcycle maintenance, you MUST rediscover what you do as you go. Rigid values makes this impossible.” ― Robert M. Pirsig, Zen and the Art of Motorcycle Maintenance: An Inquiry Into Values |
