Fire Damage
Here are some pics of my recent fire damage.
Here is an overview.
Almost all of the damage was to the left side of the engine.
The majority of what got burned was the ignition components/wiring from my MegaSquirt conversion and my LC-2 wide band controller. I removed those items to see what other damage was below those parts. The plastic bits melted and dropped down. It looks like the main fire and heat was on top of the ignition components.
Thoughts on potential damage which can not be seen?
Damon
Damon in STL
1977 widebody with 3.0
1989 BMW M3 M42 1.8 Turbo Race Car
Old 06-14-2015, 12:48 PM
weekend wOrrier
Sorry about your fire. I don't know about hidden damage, but, do you know what caused it? I'm thinking of going to efi in the future and don't want a barbeque.
Old 06-14-2015, 01:17 PM
Fire is usually on the left side because that's where the fuel lines are along with the sparks to ignite it.. The good thing is fire burns up and the motor itself just needs cleaning.
Bruce
Old 06-14-2015, 01:27 PM
I am so sorry for your losses. I hope you can get it back together like it was. That is afterall what insurance is supposed to do.
Good luck,
Dave
Dave McKenzie
1984 Carrera 3.2
1984 928S Automatic
2001 996TT
Old 06-14-2015, 02:45 PM
See my earlier post. It describes what happened. A garage fire caught the car on fire.
Spontaneous Combustion
What I'm concerned with are any o-rings or other plastic internal parts. There was a lot of heat up high in the garage...but, luckily when the garage door switches shorted...both doors opened. Although this may have provided more air to the fire...it may also have provided cool air down low.
Damon in STL
Old 06-14-2015, 02:48 PM
Das Schnell Ei's Avatar
That does not look that bad... you can still tell what most things were
You running an MS setup?
'77 911S Coupe 3.2 Turbo
'76 911S Coupe 3.0 964 cams...no sunroof
'75 911S Cabbie 3.2 SS Web cams & 46mm Webers
'73 914 1.7 Webers & Header ... sold
'74 VW 1303S 1600cc DP Web 110 & Solex
Old 06-14-2015, 03:32 PM
Yes, MS for both fuel and ignition. All that is really damaged on the outside were the plastic/rubber parts.
Damon in STL
Old 06-14-2015, 03:44 PM
look up my old post on a fire damaged 82 sc. the car I bought also had a megasquirt system and a fuel line failed. I cleaned up the engine put a CIS system back on it and it runs fine.
Old 06-15-2015, 08:05 AM
Sorry for your loss hope everything gets back to normal
Old 06-15-2015, 02:18 PM
