Send a message via ICQ to fred hannah
need quick help-engine removal
ok im in a jamb. got the motor lowered down, everything unhooked, four motor to trans. bolts removed, but cant get the motor to seperate all the way. i cant get it seperated to the point that i can see the flywheel form the engine compartment but thats it. its like something is hanging up inside the trans. any help would be great.
fred
Old 11-17-2002, 09:08 AM
forgot to say its 1970 2.2t with 901 transmission.
fred
Old 11-17-2002, 09:09 AM
Senior Member
Doug Zielke's Avatar
From the Workshop Manual.....
1) Remove starter from trans and turn flywheel until each of the 3 rivet heads on the pressure plate are visible through starter opening.
2) Install a spacer sleeve on each of the rivet heads and fasten with M6 x 12 allen head bolts This will lift the diaphragm spring and release tension on the throwout bearing.
3) Turn throwout bearing with a screwdriver through opening in trans housing 90 degrees until throwout can be slid past the throwout bearing.
'81 SC Coupe "Blue Bomber"
"Keep your eyes on the road, and your hands upon the wheel."- J.D.M.
Old 11-17-2002, 09:24 AM
Home of the Whopper
Are you trying to remove the engine without the tranny? Just take out the two tranny bolts and disconnect the shift coupler and drop the whole thing. IMO much easier for removal and installation. I have never had to use steps 1 and 2 on the procedure Mr. Zielke outlined, just step 3.
Have fun!
BK
Old 11-17-2002, 09:53 AM
Bandwidth AbUser
Jim Richards's Avatar
BK's right, taking the motor & transaxle out together is real easy. Separating them after their apart is much easier, too.
Jim R.
Old 11-17-2002, 11:17 AM
Crusty Conservative
silverc4s's Avatar
PLUS - You can find ways to spend $$$ on the tranny while it is out as well...
Bill
69 911 T Targa, 2.4E w/carbs (1985-2001)
70 911 S Coupe, 2nd owner (1989- 2015)
73 911 T Targa, 3.2 Motronic (2001- )
Old 11-17-2002, 12:52 PM
got it out, just took thw both of them out together, ill seperate the two on monday. clean it up with lots of rags and carb cleaner right now. anyone paint their transmision before? it apears mine was painted black.
fred
Old 11-17-2002, 01:17 PM
rickeolis's Avatar
Porsche Crest Doing this too...
I'm working on doing the same, no one mentioned taking out the CV joints though.
Good luck Fred, I would like to know the progress, are you doing this to rebuild or replace the engine?
-Rickeolis-
1986 Corvette
Old 11-17-2002, 02:10 PM
