?? Regarding testing a Quaiife ATB DIFFERENTIAL
We have recently installed a Quaife Limited slip differential and are unsure of how to test this. It seems as though we cannot get the two wheels to spin independently of each other. Is the Quaif edifferent from other LSD's in that sense that it takes much more torque to break them loose?
Jack the car up on one side. With a wrench turn the engine over. The raised side wheel should turn, and the wheel on the other side should not be trying to drive the car off the jack.
The Quaife supposedly provides no useful lock if one of the wheels is unloaded entirely, or loaded no more than some small percentage - say 10%. So this check should tell you. I think there is enough internal friction, though, that with both wheels off the ground, turning one will cause the other to turn in the same direction if the transmission is in neutral. However, by holding the other wheel, you should be able to turn the wheel and have all that turning be done in the transmission. I can't say as I have ever thought to test the couple of Quaifes I have installed in my cars. Spent plenty of time getting the lash right, but that was it. They seemed to work fine (within their limitations) on the street, autocross, and track. |
A Quaife isn't a limited slip differential. It is a torque biasing differential. If you jack up the car and spin one wheel the opposite will will spin the opposite direction.
Why do you feel the unit needs to be tested? |
When the car is up in the air on the rack we cannot get the two wheels to spin independently at any time. It acts as though the differential is fully locked all the time, we have put quite a bit of torque and cannot seem to get them to act anyway other way than fully locked. The differential looks really good I bought it from a parts dealer who said it was in great shape but we are unsure as to how this differential is supposed to behave. Because it is unlike the normal differentials that we have traditionally tested with the torque wrench. Thanks in advance for the help
Which direction are the wheels spinning? In the same direction?
Let me finish dinner and I will get you some internal pictures that might help. |
They are spinning in the same direction thank you
That does not sound right. It should act like an open diff (opposite directions) with the car in the air.
Exactly that's the Issue. Doesn't make any sense it looks beautiful
You haven't told us what year and model vehicle. It wouldn't surprise me one bit to learn that the G50 model Quaife is STILL made incorrectly after all these years.
The issue is that while one flange installs correctly, the other sits too deep. The deep side locks up on the diff body. The fix is a small shim installed beneath the stub. |
A flange that locks itself to the differential housing does not extend far enough into the differential, and does not fasten itself to the diff internals. It would be too short in depth. As I recall, early Quaife TBD's for Porsches were based on dimensions of the 69-75 ZF LSD, which used flanges 5mm longer than the standard Porsche differential. |
I guess we need to learn what year car we're talking about.
To reiterate: on the G50 model, the design was (still is?) incorrect, so the flange's shaft on one side ended up being too short .. but because it isn't the flange that's incorrect, I say the flange sits too deep. So, pretty much the same issue, but only by 1-2 mm, not 5mm like the early flange length difference. |
Mystery solved , whoever had reassembled this differential had flipped around one of the internal gears thereby making the endplate offset three extra millimeters . This resulted in the differential staying locked all the time. Once we disassembled the differential it was obvious that this gear had been positioned 180 degrees upside down therefore making the differential essentially locked and useless. http://forums.pelicanparts.com/uploa...1434501951.jpg
http://forums.pelicanparts.com/uploa...1434501979.jpg In the photograph you can see the gear that stands proud. Where I have indicated with the drill bit there was a gap of 3 mm because the gear did not sit into its normal recess. Once we figured that out everything went together properly. Unfortunately we had sent the transmission case cover to the machine shop to mill off 3 mm before realizing that the differential had been assembled incorrectly. This is unfortunate because the person I bought this part from is a reputable seller and his contact that sold him this piece apparently was not representing this differential for what it was. Such is life Turning a four or five hour differential job into a 10 hour job. With the added expense of machine work. |
Interesting. My 3.6 G50 cab has a Quaife ATB diff installed (I purchased the car this way). I'm thinking I'll test the diff by spinning the wheels with the car in the air and see what happens.
The diff I have seems fine. I know it's providing torque biasing (locking) and I think I'd know if it wasn't unlocking but I'll test it to find out for sure. |
Well, that's a bummer, but at least the mystery is solved.
One should never need to machine their case or sidecover when installing an aftermarket differential. Folks should take that as an indication that something is very wrong and not proceed without further investigation if they ever encounter a similar situation. Glad the op figured it out and resolved it. If you tell us what gearbox this is, someone here may be able to provide a replacement sidecover for the one that has been machined.
No, he's not going to tell which gearbox it is, Matt! ;)
It's a 944 Turbo gearbox that is being used with the 6.2 GM Erod motorhttp://forums.pelicanparts.com/uploa...1434552918.jpg
http://forums.pelicanparts.com/uploa...1434552971.jpg Requisite 911 content |
Sweet!
The machining just provides more clearance than is needed now that the diff is correctly assembled?
Fun project. I think a Chevy swap in a 944 is a great combo. I call it a 948. The car that Porsche should have built but didn't.
I checked the Quaife on my '77 turbo. With both tires off the ground, the tires turn the same direction. If I stop one side, I can get the free side to turn but it takes 50 ft-lbs of torque to do it. Is this right? The Quaife has been installed since the early 90's.
Bump
Matt, Walt, Geary, Any thoughts on my Quaife test results? Both wheels turn the same direction. If I lock one wheel, it takes about 50 ft-lbs to turn the free wheel. |
I don't have much experience, but I know you can turn a helical torsen easily by hand when it is not installed. There are some diffs that combine friction plates and torsen gearing but I think the Quiafe is a pure gear type.
I e-mailed Quaife USA to ask the question about testing a Quaife to verify it is installed.
They provided the following steps to check for a Quaife installation: 1. Lift the drive wheels off the ground 2. With the engine off, put the car in any gear. 3. Rotate the Drivers wheel clockwise. The passenger wheel should rotate counter clockwise. 4. Block or lower the passenger wheel so it cannot turn. 5. Try to rotate the Drivers wheel. It should not turn but about 1 inch in either direction. If it does not pass these tests, then it is either not a Quaife or a damaged unit. I did the checks as prescribed and my Quaife met the criteria. However, step #3 required the use of a lever arm to turn the hub. That may be too much frictional torque. They said to do step #3, you should be to rotate the tire by hand. I am waiting for a response from them on this. |
Issue for me is that with both wheels in the air and with the transmission in neutral, I can barely turn the tires, it takes major force to make it turn...not smooth at all, so much so that I can't even do it and see what the other side is doing at the same time. The transmission was fully rebuilt about 8 years ago and then stored (oil in) in a dry location and has never been put into service. I actually do not recall when I got it back even trying to spin the output shafts....so have no comparison. Anyway, it seemed like you were having some similar issues and wondering what Quaife told you about the force necessary to turn. Thanks in advance for any further insight you can provide. D. |
Parking brake or disc brake dragging?
Pretty sure they are loose, but need to confirm as per your suggestion. D. |
Ok, an update and my blood pressure is down.
The car has fairly stock 1989 Carrera suspension but I do have the Elephant ASP system installed along with Fuchsfelge wheels and the spacers recommended by Fuchsfelge for this car which was 32 mm spacer for the front and 21 mm for the back. I dutifully followed this recommendation although I challenged the front/rear spacers as I thought it was the other way around with the larger spacer in the back. Well, I was right. With their spacer combination, the rear tire rubs against the trailing arm/ASP to the point where you can barely turn the wheel/tire. So after some careful measurement, I figured I needed a rear spacer of - you guessed it - 32 mm in the rear and after checking the front, they turned out to be spaced out too far and needed a spacer of around 20mm. So, reversed the two, everything fits properly now and I am ever so thankful that the Fuchsfelge wheels have deep pockets where my now too long rear studs fit without problems. I am buying new studs for the front, fairly easy to do, just have to take the front hubs off and swap them, no rear bearing problem to handle. So that was it, transmission spins fine with the tires not rubbing the suspension. Not a Quaife problem at all... D. |
| All times are GMT -8. The time now is 07:45 AM. |
