Speedster_'s Avatar
Test speedometer? and transmitter?
My speedometer is not working at all… Since the wiring, gearbox and speedometer are from different cars I don’t know where to start fault tracing. I think the wiring is right with + connected to + and the two cables from the transmitter connected to the two bottom connectors (the one in the bottom also have earth to it).
Is there some why that I can test the speedometer? And the same for the transmitter in the gearbox?
Petter
Porsche "The Hulk" 993 RSR
Old 06-16-2015, 03:09 AM
The Bavarian
Switch a muli meter to measuring ohms and connect both sensor terminals. Jack up the rear of your car so both wheels can turn free. Turning a wheel should give you eight pulses per revolution on the multi meter (Switch between low and high ohm value).
- Manfred
'80 911 SC Targa black/black
Old 06-16-2015, 08:12 AM
Speedster_'s Avatar
Thanks, I will try this!
Petter
Old 06-16-2015, 10:38 PM
