915 Transmission Thrust Washer Placement
Replaced a couple of synchos and bearings in my almost perfect 915 trans and now I am stuck on where the kind of beveled thrust washer goes. I can't seem to find a parts diagram that shows thrust washers other than flat. Does it go on the end of the output shaft, like in the picture, or maybe on the input shaft somewhere? I know, should have kept better track, but I didn't and this is where I am.
Mainshaft, under the bearings.
Here?
Do you mean number 16 in the picture?
Yup.
