Havolas (guest)
Guest
Posts: n/a
1977 Porsche 911S. Ok, pretty sure car not starting due to faulty ignition switch. The only ones I see here at Pelican are listed starting in '84. What is the correct item number for my particular year? Thanks!
This post was auto-generated based upon a question asked on our tech article page here:
Old 06-16-2015, 04:41 PM
The original part number for your switch is 91161301701, which is no longer available You must use: 964-613-012-00 INSTEAD ** IGNITION SWITCH**
- Casey
