-   -   I have a 1970 911T. Rarely do I drive it in the rain. Had to yesterday. This morning the neither turn signals work. Don't think it's a fuse since both are not working. Any ideas? (http://forums.pelicanparts.com/porsche-911-technical-forum/871001-i-have-1970-911t-rarely-do-i-drive-rain-had-yesterday-morning-neither-turn-signals-work-dont-think-its-fuse-since-both-not-working-any-ideas.html)
Marken (guest) 06-16-2015 05:04 PM
I have a 1970 911T. Rarely do I drive it in the rain. Had to yesterday. This morning the neither turn signals work. Don't think it's a fuse since both are not working. Any ideas? Thanks!
This post was auto-generated based upon a question asked on our tech article page here:
Casey at Pelican Parts 06-16-2015 05:04 PM
Could be a faulty hazard switch, or turn signal switch. First remove the lenses and see if there was any water intrusion where it shouldn't be, then check under the dash for any areas of water intrusion. Chances are something got wet that wasn't supposed to. A good visual and then a thorough drying out of whatever you find will likely solve your issue. Is your windshield seal cracked? The seals around the turn signal lenses or taillight lenses cracked? Does the turn signal switch feel like it should? Do the hazard flasher lights work? Do the indicators in the tach light up when you activate the turn signal switch?
- Casey
Marken 06-16-2015 05:14 PM
- Casey
Thanks Casey. I'll check it out and reply a bit later.
