Fleabit peanut monkey
Removes all doubt. Back in a few.
1981 911SC Targa |
Connect all three center ones together. Two flats (87's) and the vertical (30) with the wire. That's it.
Freq will run if all else ok. Betcha it does. Listen near engine.
1981 911SC Targa |
Gotcha bob thank you ill try it tonight when i get off.
TMI, Broseph. Your sex life is your business.
1981 911SC Targa |
Ok tried the jumper and .... nothing this was with key on the on position engine not running.
You sent juice directly to the freq valve. It did not energize. Now you have to confirm the valve is dead or there is a circuit interruption. This has nothing to do with the Lambda box (at this point). Meaning this does not confirm the box is or is not working. Now you can sniff at that 12 pin. Harbor freight sells a pretty good multi meter in the low $20 range if you are not a tool fancy pants. Gonna need that.
1981 911SC Targa Last edited by Bob Kontak; 06-18-2015 at 09:36 PM.. |
Kind of a pain to get that wire off but very do-able. You don't really have to see it. Just understand where the spring wire ends are and use the right tool to dislodge it. It is the correct place to start.
1981 911SC Targa |
Ok thanks for all the help much appreciated ill report back tomorrow
No power at fv conector
Cancel that ,
Ok so no power at fv with oxs relay installed. POWER at fv with wire jumper installed in oxs relay port. But fv still will not kick on does this make any sense? Last edited by 911 sc; 06-19-2015 at 01:08 PM.. |
By the way, when was the last time it was working? Not trying to be silly, but that could be very helpful when trying to diagnose a problem such as this.
Let me research. For grins, see if you can take the other connector and establish ground with the engine case.
1981 911SC Targa |
Both of the wires go through the 12 pin connector.
Terminal #2 (power) and Terminal #1 (back to Lambda Box). The 12 pin has the little numbers cast into it.
1981 911SC Targa Last edited by Bob Kontak; 06-19-2015 at 01:44 PM.. |
It worked fine last week then twice it spit and spudderd so i shut it off.. restarted to no idle and backfiring
Why am i getting power to the fv with the jumper and not the relay but still will not turn on the fv? Could it be the ecu lambda box? |
2nd question. You have power on one side of the connector with the cheater wire in. Does the other side provide a ground - one lead to the other connector the other lead to the engine case with a resistance test (ohms)? Check this using the ohms function on the multi meter. If you don't know how to do this it is perfectly ok. I will tell you. No ground - no fv run. Ground may be interrupted at the 12 pin connector or by the Lambda box being faulty OR the FV being bad and ground then is meaningless.
1981 911SC Targa Last edited by Bob Kontak; 06-19-2015 at 02:45 PM.. |
Oh, Man. Good job. This may or may not be an issue. However, when you find something like this it raises and eyebrow.
If you have a multi-meter, tell me what kind. If it is the "free" harbor freight kind, go there again and spring for the miraculously on sale again, #37772 multi meter. - $23.99 - it is well worth that amount. It will pull you out of this. If you have a rdecent multi meter, then advise and I will set you straight. This is now a pretty straight-forward exercise if you have the right info.
1981 911SC Targa |
