22mm Swaybar Bushing
So I rebuilt my steering rack and in the mean time I replaced the swaybar bushing. I was able to install the A-Arm bushing with no issue but I can't seem to get the pan on that holds the swaybar in place with the new bushings to save my life. Any advice?
![]() ![]() ![]() Correction: 20MM Bushing Last edited by zl0ca; 06-21-2015 at 03:36 AM.. |
83 911 Production Cab #10
If its for your 83, it should be 20mm bushings.
The 22mm bushings are for 86 to 89.
Who Will Live... Will See ![]() ![]() ![]() 83 911 Production Cab #10, Slightly Modified: Unslanted, 3.2, PMO EFI, TECgt, CE 911 CAM Sync / Pulley / Wires, SSI, Dansk Sport 2/2, 17" Euromeister, CKO GT3 Seats, Going SOK Super Charger |
cycling has-been
You have to lie on your back directly under the allen bolt hole and align the strap and the pan and the crossmember by sight. You might have to hog out the bolt hole in the pan to ease your pain. 2mm (especially 2mm of rubber) should not prevent the pan from being re-secured.
Bill K
73 911T MFI, 76 912E, 77 Turbo Carrera Last edited by bkreigsr; 06-22-2015 at 09:08 AM.. |
