-   -   So my frequency valve is not working (http://forums.pelicanparts.com/porsche-911-technical-forum/871213-so-my-frequency-valve-not-working.html)
911 sc 06-18-2015 08:53 AM
1982 911
What to check for first?
What causes the frequency valve to not kick on other than the oxygen sensor relay?
I have a new relay on order from our host but it will not arive until next week I was wondering what else I can check.
thank you
T77911S 06-18-2015 09:41 AM
fuse 18
911 sc 06-18-2015 09:54 AM
Ok checked fuse 18 still nothing
911 sc 06-18-2015 01:10 PM
Anyone
Dave Kost 06-18-2015 01:32 PM
it could be the ECU too. I just went thru this with my newly acquired 83.. Both the ECU and relay wasn't working. Chances are that it is the relay only.
gazzerr 06-18-2015 01:36 PM
Could be the oxygen sensor itself. The FV might be actually working but the duty cycle is so low you can't hear it. I'd check that the sensor is actually plugged in and working. My FV was not audible until I changed out the old oxygen sensor, then I could hear the FV working away.
Bob Kontak 06-18-2015 01:38 PM
There is a way you can cheat the system and test freq valve with key off. You have to jumper the relay ports with a wire. Let me find the correct post and will link it in an edit in this post.
Here is the link. See post 13. I was on the phone with the original poster of this thread when he got it working using this method. Let me pull the test on my car right now so you don't screw something up based on my recommendation.
http://forums.pelicanparts.com/porsche-911-technical-forum/559200-911-sc-running-flat-no-idle.html
911 sc 06-18-2015 01:51 PM
Dave i tryed calling you but your phone was off. Give me a call at your convenience thanks
911 sc 06-18-2015 01:54 PM
Yea im thinking it may be my ecu because my old relay is clicking but fv still not running.
Could the relay be bad but still click when i plug it into the running car??
By the way symptoms are rough idel backfires will not rev up spits and sputters.
thanks
Dave Kost 06-18-2015 01:59 PM
Dave Kost 06-18-2015 02:02 PM
i sent you a pm. i am away until july 14th.
Bob Kontak 06-18-2015 02:20 PM
You can't be sure right now. You can have a perfect relay and a perfect ECU and the 12 pin connector by the driver's rear shock could have a corroded connector not allowing voltage to your freq valve.
Can click all day.
Still working on confirming this mentioned test for you.
These are your symptoms, correct? I pull the relay at 23 seconds in.
<iframe width="420" height="315" src="https://www.youtube.com/embed/5tdpCYyvqSc" frameborder="0" allowfullscreen></iframe>
911 sc 06-18-2015 02:29 PM
Yes my syptoms, however my car may be backfiring more as soon as i touch the throttle
Bob Kontak 06-18-2015 02:34 PM
I had the cover on the air intake and the camera does not really pick up the "pop' very well.
Confirmed test. Taking some pics so you can perform if you choose.
911 sc 06-18-2015 02:39 PM
Ok thanks bob much appreciated and ill check the 12 pin connector too
Bob Kontak 06-18-2015 02:43 PM
The top two middle connectors are the two 87's. The bottom middle is the 30.
Flankers are not necessary for test.
Wire the base of these three prongs together (A PITA) and plug in.
Preferably if you can use a wire like I crafted and plug them into the corresponding female ports on the wire loom that will send 12V to the freq valve.
You cannot hear it run when under the passenger seat. You can hear it run through the engine grill.
Good luck. Worked for me just now.
If nothing, then more digging.
http://forums.pelicanparts.com/uploa...1434663782.jpg
Bob Kontak 06-18-2015 02:47 PM
Don't do that now as it is pain (the connector itself). Your relay may just be tired or cooked.
This will absolutely confirm that juice is or is not getting to the freq valve. If it confirms, screw the extra work.
Well, it can confirm that freq valve is toast but that is VERY rare.
tkmoore 06-18-2015 02:51 PM
If you end up needing an ECU let me know. I've got one avail for 80-83 sc cars. I bought it from a pelican recently to help diagnose if mine was bad and it turned out to be an entirely different problem so now ive got a spare ECU. Tim
911 sc 06-18-2015 02:51 PM
Ok just so im understanding correctly wrap the three said prongs together and run three wires to the corsponding female ports and this should kick on the fv while key is on?
911 sc 06-18-2015 02:52 PM
Thanks tkmoore ill keep you posted
