78 SC Flag Mirror motor only goes one way
As the title says, my 78 passenger flag mirror only goes out and in even whence plying the joystick up and down. I replaced the motor unit with a correctly functioning one and still side to side only, no up and down.
I'm having a hard time understanding how the mirror positioning switch/joystick could malfunction this way, but I'm happy to be enlightened. Can the rocker switch that controls left and right operation cause such a glitch? Any information would be greatly appreciated. TIA chris |
My bet is the right hand motor may be tired in the up down movement or the pin connectors in the mirror are corroded/broken at the wires. Moderate job, mainly tedious, once you spool up for it. Need to do some searches. |
Interesting - a signal issue vis-a-vis the wiring before the motor, at the connector. This is something I can work with. Perhaps a schematic would help. I guess with both mirrors doing the same thing, I can eliminate the mirror.
Thanks for the idea, bob. |
Do both sides do the same thing? No up and down? |
| All times are GMT -8. The time now is 10:23 PM. |
