Rear Bumper Fitment
Need a little help with the installation sequence for the bellows, rear bumper seal, and the bumper extension. The seal is too long, so it'll need some trimming. Should the cut be 90 degrees or angles? Does the top flange on the bellows tuck under the tail light housing? Thanks!
Actually, does the top bellows flange tuck under the thin section of body under the tail light housing...
