-   -   MSD install no tach (http://forums.pelicanparts.com/porsche-911-technical-forum/871540-msd-install-no-tach.html)
Amstaff 06-21-2015 08:36 AM
MSD install no tach
So I am totally stumped.
I changed from a 2.4 (with a working tach) to a 3.0 and installed a MSD with new blaster coil. Wired it up according to the schematics. At first I tried to wire it without a tach adapter but no tach. Bought the correct tach adapter for the magnetic pickup and still no tach.
I checked to make sure that the tach was wired correctly and that the red wire going to the tach has power and that the black/purple wire was securely connected.
I also checked continuity of the black/purple wire from the engine compartment to the tach.
Any ideas? Could I have done something to mess up the tach? How would I test it to see if it is bad?
This is on a 1972T
Thanks in advance
timmy2 06-21-2015 11:19 AM
Did you confirm the tach wire is in the correct location in the 14 pin connector from the engine harness for the '72?
mreid 06-21-2015 11:23 AM
With the MSD, I don't believe the tach signal goes through the 14 pin connector (on mine it doesn't). You also need ground on the tach. You need to snip the correct wire(s) in the MSD box. You need the correct tach adapter (usually 20).
Amstaff 06-21-2015 11:32 AM
I am not sure about the 14 pin connector. I just ran the purple/black wire to the tach adapter (it is a 20).
I snipped the correct wire on the MSD box
Is there a place on the tach to attach a ground wire?
Bob Ashlock 06-21-2015 12:01 PM
Common problem. Your 2.4 tach likes a low-level signal. The MSD does provide such a signal but I think it is on a separate output port on the side of the box. In my experience, an adapter should not be needed. If the tach gets accidentally hooked up to other places (like the coil, or an adapter that pushes a high level pulse out) it will be instantly damaged.
Amstaff 06-21-2015 12:07 PM
I did hook it to the coil initially.
Is there a way to check if the tach is still functional?
timmy2 06-21-2015 12:30 PM
Why not describe each connection you made and what you changed on the 3.0 engine harness.
Are you running the 3.0 dizzy with the green wire? It was an original 6 pin connection correct?
The purple/black tach signal wire in the 3.0 harness runs to a different terminal in the 14 pin connector than the '72 does. The 3.0 has it on pin 12 and the 72 has the tach wire from the engine harness on pin 9.
The '72 pin 12 is ground for the alternator , so if you connected the tach output to the purple black wire on the 6 pin CDI connector, it is going directly to ground.
mreid 06-21-2015 01:29 PM
Eww, that could be bad juju. I thought you tried the tach output on the MSD box first. If you are using the -20, didn't you connect it to the box tach output? Connect the purple/black directly to the box tach output and report back.
timmy2 06-21-2015 02:44 PM
It really would be helpful to know how everything is hooked up for the 2.4 to 3.0 conversion and the MSD installation.
Can only guess what you did otherwise.
Amstaff 06-21-2015 02:59 PM
I used the harness that was on the 3.0. Plugging it right into the harness.
Everything worked perfectly except the tach.
Do I need to connect it to a different wire from the harness? What color is the tach wire on a 3.0 harness?
Amstaff 06-21-2015 03:06 PM
MSD box
Big red to starter
Black to ground
Small red to power by key
Purple and green to distributor
Red and black wires to coil
White is not used
Tach adapter
White to tach connection on side of MSD box
Red to keyed power
Purple to purple/ black wire
timmy2 06-21-2015 03:41 PM
Move the purple and black wire in the female 14 pin connector of the 3.0 engine harness from position 12 to position 9.
Just swap the green white in position 9 with it or move the green white to the empty position 7.
The green white wire is from the oil pressure idiot light sender of the 3.0 that you don't need anyways.
The position numbers are on the back of the connector.
Amstaff 06-21-2015 03:42 PM
The purple/black wire is #9 coming out of the harness.
Amstaff 06-21-2015 03:44 PM
The purple/black wire is in the female #9 position.
timmy2 06-21-2015 03:49 PM
Test the tach wire from the back of the gauge to the output of the tach adapter for continuity with a meter. If it is good, then as someone else mentioned you may have a bad tach if you connected it to the coil.
(Long jumper from meter leads to reach back of tach wire required)
Amstaff 06-21-2015 03:57 PM
Did that and have continuity
Jonny H 06-21-2015 04:13 PM
Most 911 tacho 'drive' signals just pull the TD signal wire to ground. Grounding the wire momentarily (or scrape it across a ground to create 'pulses') should cause it to bounce at least. Ignition on obviously.
timmy2 06-21-2015 04:18 PM
Well, if you have continuity from the tach adapter purple wire all the way to the tach, and the car runs normally, then I think it is time to test the tach or the MSD unit and adapter.
Do you have access to a working tach you can borrow or the instruments and ability to test the tach?
If not, send it out.
Jonny H 06-21-2015 04:32 PM
I wouldn't put a another working tacho in the car if the install blew the first one.
Pull tacho, it should have 12V and ground and the input TD wire. Check the first two with a meter, then just ground the input wire, needle should bounce.
Amstaff 06-21-2015 04:36 PM
I pulled it and checked the 12V wire and it is good.
I will pull it again and check the ground and tach wires
