Accessing the windwiper assembly
Need to access my wiper motor assembly. Have removed the cover in the trunk and the blower motor assembly. How does one remove the plastic ductwork in front of the wiper motor? Looks like there are clips that may possibly hold 2 pieces together? Thanks Jerry
Old 06-23-2015, 02:04 PM
Send a message via Skype™ to Porboynz
Disconnect everything and remove the entire fresh air assembly. If you split the 2 halves while its in the car you will never get it back together. (assuming its even possible to pop the clips all the way around, which it probably is not)
1972 911T Coupe with a '73E MFI engine and 'S' pistons
10 year resto mostly completed, in original Albert Blue.
***If only I didn't know now what I didn't know then***
Old 06-23-2015, 11:49 PM
ganun's Avatar
To gain access to the bolts and electrical connections that hold the wiper assem to the car you also have to pull out the speedo tach and clock, not quite sure which two exactly but its easy enough, take pics cause its a bit tricky arrangement of parts, as usual!
87 911 coupe, GP white, cashmere/black
64 Alfa Romeo Giulia TI - the violin
89 Peugeot 505 Turbowagon-other Pcar
67 912 coupe, white, sold
04 Audi Allroad 2.7T
Old 06-24-2015, 06:10 AM
I Have pulled the speedo and clock and see what I need to fix. But need to access the front to do the fix. Need to pull that fresh air assembly. Does it just pull out or are the bolts holding it in. I didnt see any yesterday?
Old 06-24-2015, 08:44 AM
steely's Avatar
never did it, but I saw this link from a while back.
looks like the black bracket and some screws in the vent opening as a minimum.
Need to check windshield wiper motor and relay for possible replacement
Dan
'87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip
Venetian Blue
Old 06-24-2015, 09:16 AM
pete3799's Avatar
Two bolts under the fresh air intake screen need to be removed.
Pete
79 911SC RoW
Old 06-24-2015, 12:31 PM
Thanks for all info. Got it fixed!
Old 06-25-2015, 03:17 AM
