I have a Fluke 73III multimeter. A few posts back I posted my results. How will a test light work differently? Are there settings on the Fluke that will simulate a test light?
You didn't mention any numbers with the air flow switch test and I think there is supposed to be a ground closure when the plate is active. With your meter you could go to pin 85 on the relay and see that it goes to ground (near 0 Volts) when you lift the plate. |
For the air flow switch test I hooked up a volt meter. It read 12 volts and then when I lifted the plate it fell to zero. Would measuring the resistance with an ohm meter be helpful?
I'm more than happy to run out and buy a test light this morning if it gives me the right info to diagnose the issue. |
If that is the case what is this?
That is testing with the relay in the socket and the key on. I was just testing from ground with the volt meter and the positive terminal on the relay pulled out of the socket a little bit. (I admit and mentioned that I wasn't sure if I was performing test#3 correctly.)
For the air flow switch test I hooked up a volt meter to the battery (+) and hole 85 of the FP relay socket (no relay installed). It read 12 volts and then when I lifted the plate it fell to zero volts. I'm more than happy to run out and buy a test light this morning if it gives me the right info to diagnose the issue. |
EDIT: and it seems the voltmeter readings should be opposite of what you describe |
the other thing is a TL helps check for power with reference to ground since the clip should be on chasis ground. if you need to check the ground side of a circuit, clip the TL to 12v. |
Three minute job........
Anthony, This is a good example of a three-minute job that becomes a major work. For the FP relay and socket test, a test light works best because: a). You want to see power @ 87a, 87, 86, and 30 terminals with the ignition switch at these positions (OFF or ON). b). Terminal #85 (FP relay socket) is a ground wire. Use the multi-tester @ continuity setting. c). AFM switch has two terminals. One goes to terminal #85 and the other one goes to terminal D- (alternator). Test continuity using the multi-tester. Test your FP relay. Terminals 87a-30 are NC (normally closed). Terminals 87-30 are NO (normally open). When you turn the ignition switch @ ON/RUN; The NC terminals (87a-30) will be energized if terminal #85 is grounded (at the AFM switch) and NO terminals (87-30) will close. This is another scenario if terminal #85 is not grounded (open). After you turned the ignition switch @ ON position (not start), the NC terminals 87a-30 will remain closed because the coil is not energized due to terminal #85 is not grounded. With the FP relay @ 87a-30, the FP will run. This is the reason why you pull the AFM switch to make terminal #85 open (no ground). Follow the logic? Any question? Tony |
Ok, picked up a test light. Will run the tests again and report back. Thanks.
Oooops this is a little more complicated than I thought.
Here is a good write up thanks to Timmy2 http://forums.pelicanparts.com/8139572-post35.html What does D- on the alternator do. All the diagrams I see it just goes to ground. |
I ran through the tests again. The thing that jumps out is no power at 87 of the socket (key on or off). To summarize:
key turned to on/run position 86 ...... power 87 ...... no power 87a ..... power 85 ...... no power 30 ....... no power I get the same result with the relay plugged in (key on/run position) I also tested 85 again back to the AFM switch. I put the test light on the battery + and at 85. The light glows. (key off, relay out). Lift the plate and the light goes out and breaks the ground. According to what you said above, I should have power at 87 so I need to trace back from there. Quote:
I also did another check 87 gets power when the key is turned to the STARTING position and power switches off when the key is turned back to the ON/RUN position. I'm studying the Bentley manual and this seems correct. 87 is supposed to be a yellow wire to 50 on the ignition switch but it is only energized when the key is turned to START. (assuming I'm reading Bentley correctly) |
87 goes to the start position on the ignition switch
EDIT: so it is working correctly as you tested it |
I see that on the schematic so it shouldn't have power with the key in the OFF or ON position. I think my 87 is behaving correctly.
I did the rest of the suggested tests.
I've read timmy2's description of the way the circuit works and it acts like the switch in the relay doesn't close back so that 87a-30 powers the fuel pump. I need a hint as to where to look next.
Confusing information.......
[QUOTE=rick-l;8693092]Because you want to know that the resistance to ground through the alternator with the air plate switch closed is low enough to allow the relay that drives the fuel pump to pull in.
You didn't mention any numbers with the air flow switch test and I think there is supposed to be a ground closure when the plate is active. With your meter you could go to pin 85 on the relay and see that it goes to ground (near 0 Volts) when you lift the plate.[/QUOTE] Rick, Are you familiar with CIS air flow meter (AFM) switch? Your post above is very misleading and would not be helpful to the OP. Have you actually done such investigation before or you simply read about it? This is a technical forum and we could agree and disagree about things and still be friends at the end of the day. Sharing our experiences with others is good and we learned from each others mistakes too. And your information is contrary to the fact about how the switch works. Tony |
Read and review post #57........
Anthony, There are a few important things you need to know: a). Is the FP relay good? b). Is the FP relay socket good? c). Is the FP electrical circuity good? Items a & b could be done under under 5 mins. Contact or PM LJ (ossiblue). He has more patient and articulate than me so I refer him. Read my post #57. You are doing fine just need some guidance and direction. Keep us posted. Tony |
Yes, I need some guidance and direction. :-) And I have read #57 and I'm not sure what to do next.
Clarification........
Anthony, In reference to DKlever48's post, there was a subsequent post I inadvertently mentioned about power to 87 and nobody noticed it. Then posted to correct the blunder. There should be no power to terminal #87 with the ignition switch @ ON/Run position. Terminal #87 only gets power when you turn the ignition switch to START position. I went over to review your test results and everything seems right. But I did not find any test in particular about the FP relay itself. Have you tested and confirmed that the FPR's (FP relay) coil is switching from 87a-30 to 87-30 when energized? The relay could be defective or the contact/s at the socket is compromised. Keep us posted. Tony |
Let me see if I understand how this system works. I think key to understanding this is to realize the run switch in the air flow meter opens when the engine is running (kind of bass ackwards). Also the wires going to the alternator just provide an engine ground.
Everything looks right except for..........
Rick, This is an excellent write except for the flow switch operation. When the engine stalls, the AFS plate drops down and closes the switch, Not open as you have stated. Maybe a typo? Tony |
I think I'm honing in on the issue. I've ran all the tests again and everything checks out.
While running a test on pin 30 of the relay socket with a test lamp and lifting the AFM plate, I noticed that just as I start turning the key (the moment the gauge lights come on), the fuel pump does run. But, it shuts off as I turn the key farther.... The ignition switch!!! I made a video. At 4 seconds and 11 seconds in, just as I turn the key the fuel pump runs for a brief moment. https://www.youtube.com/watch?v=0EnVJgug074 This is repeatable. And I know: FP is good FP relay is good wiring to the FP is good FP relay socket tests good ground and wiring to AFM is good AFM switch is good everything I've tested checks out |
Have you thought about hooking the test light up to relay pin 30 to monitor what goes on during a start cycle? You could also monitor it at the warm up regulator.
I realize now that the video doesn't show a lot unless you were there. I had the test lamp hooked up the pin 30 and it did confirm that the fuel pump was getting energized for 1/2 a second just as I turned the key. (I should have included the test lamp in the video.)
This was performed as instructed.......
A test light was connected to terminal #30 with the FP relay installed. This was part of a series of tests conducted to determine the intermittent failure of the FP to run. Anthony noticed that by wiggling the ignition switch key between OFF and ON positions he could momentarily make the test light and FP to come on. And he had replicated this several times. Tony |
Is that normal for a CIS car? That seems like an awful long time for the relay contact to transfer. Long enough to overcome the inductance in the fuel pump motor and get it to spin (to make a noise).
What happens (light indication) when you turn it to start, start the car and release the key? |
I am of the understanding that this is normal.
It's my understanding that when you turn the key to the start position that the fuel pump will be energized for 1 or 2 seconds then be de-energized when the relay switches over to the starter relay circuit. This was done to prime the system just before start up. I think that if Rick's point #3 is correct that it confirms this. Also I recall that Tbitz had to modify the megasquirt program to do this same operation when doing the EFI conversion. I may be totally out to lunch but I thought that Porsche implemented this in their circuit and therefore the one of the reasons for the red relay to allow for this delay in switching. As I said I may be totally out to lunch on this. If so disregard. |
Yes, did that when I replaced the alternator. The car even ran perfectly with no alternator installed. I probably started it 20 times to move it around. After the new alternator was installed the car ran great briefly. Voltage at the battery was good, thus the new alternator was working properly. And then it stopped running again!!! I thought it was related to the alternator so I was led down the wrong path initially.
Tony really helped me step back and test each component step by step. I really appreciate Tony's aid in helping me set up proper tests to check the FP, relay, socket, AFM switch, etc. And now I have this great understanding of the FP, relay and starting circuit. The car is still not fixed but a new ignition switch has been ordered from Pelican. I heard it's a pain of a job but will be nothing compared to the days and days I've been banging my head against this problem. Hopefully, we'll be up and running next week. Quote:
and run normally. This will bypass the #15 power provided by the ignition switch if it's really bad and power the FP relay pins. Since there's just one #15 contact on the ignition switch, no #15 power will be provided to any other electrical requirement, e.g. the light/radio, if the switch is bad. So before actually replacing the ignition switch, you need to use your test-light to check the various powers at the ignition switch, i.e. X (if it has one), #15 (run), #30 (constant power), #50 (start). |
With the test light on the circuit that connects to the fuel pump, pin 30 of the relay or the warm up regulator, what does the light show when you start the car and it stalls?
Does it flash when you turn the key on, come on with the starter and then stay on or go out when you release the key? It sounds like everything works except power to the fuel pump with the flow switch on (open). Quote:
What happens when you turn the key to start and the engine fires and you release the key? |
OT: if you see a post from someone with an almost meaningless name and posts fewer than 10, ignore and do not quote. Those posts have a hidden image linked to some site, most likely to increase their search rank. (More links increase rank.)
BTTT, I see you are in the Bay Area. I am in San Jose. PM me if you need just an extra set of hands, literally. No tech knowledge whatsoever (unless you count computers). |
I deleted my last responding to that guy. I did notice that image link in the quote. Now the guy is just repeating what I wrote. Hard to believe that this helps someone's business. |
This problem, like many, has become overly complex. It should have taken 5 minutes at
most to solve and not over 75 posts and more than a week of troubleshooting. |
points and properly tested the ignition switch, but you've ordered a new ignition switch. Hopefully this will not be a waste of time and money. The "shotgun" approach to parts replacement does work on occasion, but not always. |
I agree and I realize I'm taking a $100 chance on an ignition switch. And, if that isn't the case I've gotten a lot better with the test lamp and multimeter. :-)
| All times are GMT -8. The time now is 01:23 PM. |
