Paco Anton's Avatar
Send a message via Yahoo to Paco Anton
Seatbelt warning light
My seatbelt warning light does all kind of strange things. When I start the car it goes on (seatbelt not worn). After a couple of seconds or if I move, it goes off, regardless of what I do with the seatbelt.
I suspect the sensor is bad. Now, where is the sensor?
Paco Anton
83 SC Targa (Euro)
Old 11-11-2002, 07:30 AM
Paco Anton's Avatar
C'mon guys, somebody must know the answer to this.
Paco Anton
83 SC Targa (Euro)
Old 11-12-2002, 09:22 AM
Senior Member
Jdub's Avatar
Paco:
I did see your post, but all of this sensor c*#p is pulled from my '78SC so I cannot help you. I had wondered if you might have the shared light for the brake emergency light but no luck there either.
It is probably simpler for you to simply pull your seat, turn it over, and educate us on this matter. I haven't ever seen a post on the seat sensors and seat belt light.
John
'78 Targa in Minerva Blue
Old 11-12-2002, 09:27 AM
Moses's Avatar
This is an easy one. Pull the bulb. I have no use for the light or the buzzer so they are both disabled.
Old 11-12-2002, 09:31 AM
