74 911 Oil Pressure Sender
I don't have a/c so it looks like I should be able to directly remove / replace the sender. The issue seems to be the wrench type.. I can't figure it out... Any thoughts, photos from those who have traveled this path before would be appreciated... Mark
Old 07-02-2015, 10:34 PM
You have to pull the base, not just the sender. Remove the oil line connection. There is a hollow tube holding the base into the case. Remove the whole unit. In a vise to hold the base I use slip joint pliers because they are thin enough to get on the flats of the sender.
Bruce
Old 07-03-2015, 03:16 AM
