Jandrews's Avatar
Post Brake Spec
Quick question,
What are the wear tolerance specifications for the early cars with the aluminum "S" brakes?
Specifically I am looking for acceptable rotor and pad thicknesses, front and rear (if they differ).
Thanks,
JA
John
70/73 RS Spec Coupe
Old 10-01-2001, 09:54 AM
Post
front and rear rotors, new=20.0, minimum 18.6mm. how long you run the pads is not specified in the tech book, but with 4-6mm remaining, they get hotter faster and can fade.
Old 10-01-2001, 10:22 AM
Early_S_Man's Avatar
As with all vented brakes from '69 thru '83, the wear limit on the rotors is 18.0 mm, and minimum machined thickness is 18.6 mm.
The minimum pad thickness is 3 mm, but they tend to be tapered, so the limit would be reached when the thin end is 3 mm and thick end perhaps 4-5 mm!
Warren Hall
1973 911S Targa
1992 Dodge Dakota 5.2 4X4 parts hauler
Old 10-01-2001, 10:34 AM
