-   -   what's my noise? 78 911 (http://forums.pelicanparts.com/porsche-911-technical-forum/873158-whats-my-noise-78-911-a.html)
m962b 07-02-2015 01:59 PM
It's hard to describe, a metallic rotational rubbing sound almost. not like brake pads rubbing, but more like a high pitched humming when driving slowly.
Only when car is rolling or driving and it does not affect the noise if the brakes are on.
Thanks,
Reiver 07-02-2015 02:03 PM
That, my friend, could be a multitude of mechanical things....where does it originate from, is it rpm specific (up/down) of constant.....iotw, much more info required.
m962b 07-02-2015 02:09 PM
Nothing to do with speed, nor rpm. it seems it is in the front wheel area but even split. i would assume wheel bearings would sound more screechy. this is is really i high pitched hum of sorts. but it is consistently he same at slow speeds and is fairly loud. has nothing to do with engine at all. it does it when the engine is off and is just rolling.
emac 07-02-2015 03:06 PM
Could it be the sound you get when pads are worn. Some pads have a warning sound like what you described
Ernie
cabmandone 07-02-2015 03:17 PM
Actually, wheel bearings if they're bad enough will grind. I learned that while on vacation with my wife and 3 kids about 5 years ago. When it makes the noise try transferring weight to each side of the car (like race drivers do under a caution scrubbing tires) if it goes away when weight is applied to one side or the other it could be a wheel bearing. The other thing you can do is jack up the car and grab the top and bottom of the tire and try to push the top of the tire in and pull the bottom out. You shouldn't get any wiggle in the tire. A dry bearing can make a very annoying hum.
NYNick 07-02-2015 06:07 PM
My first thought was wheel bearings. For Pete's sake, jack the front and spin the wheels and push and pull them to see if you hear anything, instead of just posting a question.
