Due to the suction problems my rear mounted fuel pump is experiencing , Is it possible to put a pre pump or valve between the tank and the pump to prevent fuel from flowing back to the tank ???
Navin Johnson
Of course its possible... 930s have a front mounted and rear mounted pump. The early cars had the pumpson the front crossmember "pushing" fuel rather than trying to "pull" it from a source that is lower and further away
Don't feed the trolls. Don't quote the trolls ![]() http://www.southshoreperformanceny.com '69 911 GT-5 '75 914 GT-3 and others |
Any easy practical solution as to how I can venture into this ?
Does anyone know of an aftermarket pump that will not be affected by sucking from the tank and able to eject at 4-6 Bar ??
