Where in the 'H' is this supposed to go?
Before anyone says it, I have already spent over an hour using the search tool, sifting various threads for information, going through all of my pics, the Bentley manual trying to find out where the male end of the distributor wire is connected.
![]() ![]() ![]() I for the life of me cannot find or remember where in the engine it is connected to from the distributor. As trivial as it sounds, can anyone please let me know where/what this wire is connected to? Thanks in advance.
Mike '89 CARRERA #402 |
83 911 Production Cab #10
Top of the coil near the rear fuse panel (in the car).
Who Will Live... Will See ![]() ![]() ![]() 83 911 Production Cab #10, Slightly Modified: Unslanted, 3.2, PMO EFI, TECgt, CE 911 CAM Sync / Pulley / Wires, SSI, Dansk Sport 2/2, 17" Euromeister, CKO GT3 Seats, Going SOK Super Charger |
JJ is right that the center post on the cap is the one for the coil wire. But I see in the picture, it looks like the one you are holding is part of a loom of 3 so that would not be the one to plug into the center. Should be a separate wire. Now for the correct firing order, it is posted on your engine lid. Good luck.
1986 Targa Guards Red 2021 MT09 SP Last edited by brighton911; 07-05-2015 at 02:59 AM.. |
Left loom has 3 wires one of which is the coil wire
Bruce |
