-   -   Troubleshooting power mirrors (http://forums.pelicanparts.com/porsche-911-technical-forum/87362-troubleshooting-power-mirrors.html)
LeeH 11-13-2002 08:19 AM
Both of my mirrors quit working at the same time. Best I can tell the fuse is good. It appears the same fuse is used for the heater blower, which still works.
Now what? I assume the next thing to check is the joy stick switch on top of the door. How does that come out?
Any other guidance would be appreciated!
targa80 11-13-2002 08:24 AM
What about the selector switch that is on the dash. On my 80SC it allows you to select which mirror is to be adjusted.
Kurt B 11-13-2002 09:41 AM
Glad this came up. Where the wiring goes through the base into the main mirror part, there is a threaded guide through which the wiring goes. This guide holds the two pieces together. It's stripped.
I ordered a new one, but does anyone know how to put the wiring through there? I can't figure out where the wiring is joined into the rest of the loom, and the stuff inside the mirror appears to be soldered...
Glasgow 911SC 11-13-2002 10:57 AM
Lee
Not sure if your wiring will be the same as mine but try tracing the purple/black wire from (I think) fuse 14. Check there is continuity from fuse area to joystick. To get to joystick unscrew 2 philips heads that hold door top in place and remove the door top. The loom pulls away from the switch. If there isn't continuity then a broken connection is likely (either wire broke or pulled out of connector block in luggage area where it goes into the wing).
Hope this helps
