82 sc headlight inop
Running lights work, and high beams work when lever pulled back, but not when pushed forward. Low beams do not come on at all - Electrical stuff to me is 99% voodoo magic so any help is appreciated - where to start...
82 SC Triple Black
Old 07-20-2015, 11:13 AM
New-ish 911SC Targa Owner
pampadori's Avatar
Headlight switch and dimmer/turn signal stalk are both common issues. When I first bought my SC i purchased both switches new just to get that out of the way and replace them with new ones. I had read the often were points of failure due to design.
Lucky for me, it fixed 90% of my car's lighting issues. Wrong bulbs installed by PO fixed the last 10%.
Install for both is pretty easy once you understand how the HL switch is removed. There is a round nut that requires a pair of circlip pliers to remove.
'83 Targa 300k w/ freshened 3.0 with 930/52 case# 6770540 ARP and Raceware hardware - AEM Infinity 506, Triumph T595 ITBs, B&B headers, Dynomax muff, Fidanza FW, Alum PP-203whp
Old 07-20-2015, 11:24 AM
jdbunda's Avatar
Don't forget fuses, mine had issues with headlights until I thoroughly cleaned the fuse contacts, replaced with new fuses, and put dielectric grease on the fuses/contacts. The headlamp relay kit sold by our host (and others) allows the cabin headlamp switch to not have to carry all of the current of the lamps (which frequently is the cause of switch failure) - highly recommended.
John
1972 911T 3.0L Coupe
1986 Carrera Targa
1989 BMW M3
2007 328iT
Old 07-20-2015, 11:48 AM
ROW '78 911 Targa
timmy2's Avatar
Odds are the contacts in the hi/lo switch are messed up. Very common. There is a very good thread on fixing them, search turn signals.
Add the headlight relay kit as well.
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 07-20-2015, 11:49 AM
