A way to plug heater duct
I'm very excited to share what I think is a very cool and tidy way to plug your heater duct when you don't want to use your heater blower. I will be installing headers, so heat is useless. +2 horsepower because of the red top!
That's clever man!
SEARCHING FOR ENGINE 6208326 (last seen in car with VIN 9111101452) 911E Coupe -70 Carrera 3,2 -84 Sold |
Excellent, I like it.
What's the complete name/brand.......
Sniper,
I've been looking for a 2-1/2" freeze plug with a wing nut like yours. What's the brand name of your plug? The wing nut is covering it. Where did you get it? Thanks. Tony |
Nice idea. That's called a test plug. Plumbers use them to temporarily seal off drain systems in order to pressure test for leaks. I have seen them in hardware stores. I'm sure Amazon has plenty.
Dave
Dave McKenzie 1984 Carrera 3.2 1984 928S Automatic 2001 996TT |
Undocumented User
I did something similar with a rubber cap for a PVC sewage pipe in the smuggler's box AC hole.
The brand is Oatey - they're known for plumbing products. Looks like it's available at home depot.
Dan '87 Targa Carrera 3.2 - Fabspeed Cat Bypass, M&K Muffler, SW Chip Venetian Blue |
Thanks guys! I scoured Lowe's plumbing department for something. They sell rubber end caps that probably would have worked, but this test cap makes a nice snug fit. Also very cool is the plastic collar within the duct near the opening. It is designed to keep the duct from collapsing when hose clamps are torqued around it. I used a clamp to keep the Oatey plug from spinning around. You can't see it, but I also cut a thin band of rubber and wrapped it around the duct to give the hose clamp something to bite into.
+2 HP..?
Other than more cooling air for the engine I don't see any real benefit. Explain? |
Just my attempt at being funny.
Very creative!! Just shorten the hose clamp and 'hide' it behind the duct...
70 911T Sold 81 911SC Coupe84 Mustang Turbo GT 66 Galaxy 500 Ragtop (my Mother bought it new) 88 Thunderbird Turbo Coupe 69 Torino Cobra (R) Code |
Thanks! Good idea. I'll do that.
Peruse the shopping aisles at your neighborhood grocery store with ruler in hand. There might be a can of beans with the correct dimensions. A store that carries institutional size can goods might offer more selection (e.g. Smart and Final).
Paint to match the surroundings. Might blend in more than the plumbing plug. BTW, beer cans (your brand choice) are the ideal size to block the hot air ducts coming off of the air shroud (early 911). Note: Do not block air flow to heat exchangers. Sherwood |
Too funny.
Monkey+Football
This one would match the car...
http://www.amazon.com/Cherne-270-237-3-Gripper-Plug/dp/B000LG4V1M/ref=sr_1_2?s=hi&ie=UTF8&qid=1436376440&sr=1-2&keywords=test+plug&refinements=p_89%3AOatey
<Insert witty comment> 85 Targa Wong Chip Fabspeed M&K Bilsteins and a bunch of other stuff. |
Reiver
De Oppresso Liber Strength and Honor 5th Legion |
Eagerly anticipating the Porsche Classic version for $89.99
1985 911 3.2 Carrera Coupe - Constant Project - 2550lbs 2005 E46 M3- Daily Beater - 3350lbs |
Didn't you know - red make things go faster ;-)
Wayne 1980 911 SC 1960 MGA 1600 |
Diss Member
Everyone knows the real gains come from chrome and stickers!
- "Speed kills! How fast do you want to go?" - anon. - "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh -- Wayne - 87 Carrera coupe -> The pooch. |
