irl irl is offline
irl's Avatar
Send a message via AIM to irl
whats the best way to refinish/buff 915 shifter base?
Ordered a wevo and would like the shifter base to remain in sight. What is the best war to get it looking nice? I would guess glass bead blasting it would look real nice but wanted to get some opinions. Also how to keep it looking good.
79 SC unmolested
75 911 backdated RSR widebody
71 911T having fun skinny
63 356 outlaw frustrating purists
25 GTS
Old 07-07-2015, 09:41 AM
I cleaned then sanded mine smooth. Had it powder coated matte black.
1982 911 Targa, 3.0L ROW with Webers
Old 07-07-2015, 09:56 AM
New-ish 911SC Targa Owner
pampadori's Avatar
get a bench top buffer and some rouge and go to work. Will make it look like chrome. Clear coat it afterwards unless you like removing oxidation every couple of years.
https://youtu.be/4VENnWmQnRQ
'83 Targa 300k w/ freshened 3.0 with 930/52 case# 6770540 ARP and Raceware hardware - AEM Infinity 506, Triumph T595 ITBs, B&B headers, Dynomax muff, Fidanza FW, Alum PP-203whp
Old 07-07-2015, 10:27 AM
Neilnaz's Avatar
I sanded mine down and polished it with a dremel polishing bit then by hand/cloth and Autosol. Being as it isn't exposed to the elements I haven't needed to concern myself with keeping the finish.
The natural finish may work but it depends on the rest of your interior.
Cheers, Neil
Old 07-07-2015, 02:36 PM
irl irl is offline
irl's Avatar
Sounds good, don't want it chrome quality, just nice, smooth and clean looking
79 SC unmolested
25 GTS
Old 07-07-2015, 06:51 PM
irl irl is offline
irl's Avatar
ayles, that is beautiful. There is a lot od powder coat options, I'm going to check out some of the dull metallic options.
79 SC unmolested
25 GTS
Old 07-07-2015, 06:53 PM
I used fine emery paper and Solvol Autosol to shine mine. It's a metal polishing paste, don't know if you have it over there but anything similar will do. Looks great
Old 07-07-2015, 10:13 PM
I have a crummy-looking spare base that I have cleaned up in hopes of finding a Wevo shifter someday. I used wet-or-dry sandpaper by hand with some soapy water and then cleaned up with Scotch-brite (to take down the "big stuff" and get it somewhat smooth). Then I hit it with two coats of VHT black crinkle paint. It has a nice, uniform texture that hides all the corrosion pits...
I'd like to hear your impressions of your new Wevo shifter when you get it installed.
Old 07-08-2015, 07:57 PM
irl irl is offline
irl's Avatar
Fan I'll let you know. I must say I was a bit surprised how little there is to it for 600 bucks. I know they are great and it's why I ponied up, but man, struggling to see why it has to cost that much.
79 SC unmolested
25 GTS
Old 07-08-2015, 09:15 PM
Cars and Cappuccino
tdw28210's Avatar
There is a build thread here somewhere where the owner chromed the top plate on the shifter base. It really looked sweet on top of the black powder coated base.
Old 07-09-2015, 05:22 AM
