Quick oil question!! Yes I've read the oil thread
I'm about to do an oil change on my '71 911 and am thinking about going with Shell Rotella 15W-40. I've heard many things about synthetic oils breaking down old motor seals and causing leaks but since Rotella is diesel then I should be fine correct?
Basically, is Shell Rotella 15W-40 considered a synthetic or non-synthetic? Yeah I know sounds like a dumb question but its my first Porsche so thanks for any input!! |
I have a Fiat Spider and use Shell Rotella T in it, as it is one of the preferred oils for that car. As with other cars of that age, synthetics are not recommended and according to general consensus and also according to AutoSprint, my local shop and the best Italian car shop in the area, it is considered good for engines that should not use synthetic oil.
Brew Master
You need to check the specs. 15/40 is what I run in my diesel engines. I think they have a "dino" and synthetic version of it but I'm not certain. Again check the specs to make sure it meets the needs for the engine.
Driver
Do synthetic oils break down oil seals like you say? (Did not know that was true, but I have been wrong before.) Or are they just more apt to leak if the seals are already a bit compromised?
I have run Rotella in the past, but there are several different varieties of it now--look online to see what specs SHell lists for each specific weight. It's the zinc content that is important for our flat tapper engines.
1987 Venetian Blue (looks like grey) 930 Coupe 1990 Black 964 C2 Targa |
Thanks all |
I think this link to Shell will answer your question: Shell Rotella® Products - Shell Rotella
Best, Tom |
Driver
Rotella T is non-synthetic IIRC
However, there are other types of Rotella that are semi- and full synthetic
Thanks guys |
Yes Rotella comes both ways, I use non synthetic. I would use the fancy stuff that everyone has gone to if I could get it locally but I cant and I dont want to pay to ship a case of already expensive oil.
Interesting note, I am getting ready to do my yearly oil change (<3000 miles, 1 track day) and the oil still looks like pretty new oil. I dont know if that's the Rotella or just a tight motor? at 100K miles I would expect some ring blow by that would turn the oil black....nope. I have noticed better hot temp pressures with the rotella on previous cars and this one, seems like a good thing.
erik.lombard@gmail.com 1994 Lotus Esprit S4 - interesting! 84 lime green back date (LWB 911R) SOLD ![]() RSR look hot rod, based on 75' SOLD ![]() 73 911t 3.0SC Hot rod Gulf Blue - Sold. |
This is what most likely to purchase: -non-synthetic -15w40 Shell Rotella T 15W-40 Heavy Duty Diesel Oil, 1 gal. - Walmart.com |
New-ish 911SC Targa Owner
I'm not sure how to interpret clean oil after a year of use.
Some folks say that's how you can tell mobil 1 is better, it is taking more contaminants in and turns dark as a molasses pretty quickly. I've run Rotella in a motorcycle with a high compression, high revving built up motor. Mostly because of fellow moto racers endorsing it. But never in anything else. maybe i should try it in the SC. In my turbo motors i've always stuck to mobil 1 because the heat that it is capable of tolerating. I ran a K26/27 hybrid non-water cooled cartridge turbo to its limits (literally, wastegate signal completely unhooked shoving 500hp worth of air into a 2.0L engine). That motor only got something other than mobil 1 when it was seating its rings the first 100 miles. Using a lesser oil probably would have coked up the cartridge of the turbo pretty fast.
'83 Targa 300k w/ freshened 3.0 with 930/52 case# 6770540 ARP and Raceware hardware - AEM Infinity 506, Triumph T595 ITBs, B&B headers, Dynomax muff, Fidanza FW, Alum PP-203whp |
I have been on Rotella Dino for years
I have higher oil pressure and each time I change it -it still looks new Ernie 81sc |
