standing water surrounding gas cap
After some heavy rains this spring, I've notice standing water surrounding the gas cap. I've put my hand down there and it seems to be a rubber gasket all around this cavity. I suspect somewhere down there is a clogged drain hole, but before I poke a stick down there and potentially break the rubber, I wanted to see if anyone could point me to the correct solution. Thanks!
Erik
'84 Carrera (2010-present)
'78 911 SC (2006-2008)
Old 07-08-2015, 07:38 PM
Registered knucklehead
83-911SC cab's Avatar
On my 83 there appears to be a drain directly below the fill neck at bottom of cavity..you can kinda see it in the pic..
Hope it helps
1983 911 SC Cabriolet, 1989 944 S2
1969 Chevelle SS396 w/427 Vette motor, 1970 Buick GS455
2000 BMW 528i Touring, 2005 GMC Sierra
Old 07-08-2015, 07:47 PM
That's it! I felt around with a bamboo skewer and had to push down pretty hard but unclogged it. The drain is a hard white plastic tube, and it's not a straight shot as it bent the skewer. Now maybe I should stop parking under so many trees...
Erik
Old 07-08-2015, 08:15 PM
Diss Member
Quicksilver's Avatar
You are missing the protective flap that is supposed to keep gas drips off the car: 91120127901
It being there could help deflect debris.
- "Speed kills! How fast do you want to go?" - anon.
- "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh
Wayne - 87 Carrera coupe -> The pooch.
Old 07-09-2015, 10:24 AM
I've got the two overlapping flaps (the pic was of 83-911SC Cab's car, not mine). The debris is there because I have to park on the street (no garage, but hope to remedy that soon), and usually try to be under trees to keep the sun off the car. But now I'll be monitoring this area--probably vacuum it out once everything dries up.
Erik
Old 07-09-2015, 10:44 AM
I got my flap as well.. Just took it and fuel cap off so he could see the drain easier..
Old 07-09-2015, 05:49 PM
