Strut brace 1982sc - any recommendations ?
Looking to fit a strut brace to my 1982sc.
Any recommendations.
I don't want weld on braces! They must be bolt on to standard strut top.
Cheers
Old 07-12-2015, 01:46 PM
Or pictures please
Old 07-13-2015, 04:51 AM
El Duderino
tirwin's Avatar
Elephant Racing has a basic and a quick change brace. I have the quick change and you don't have to weld anything, plus you can add to it as necessary.
There are those who call me... Tim
'83 911 SC 3.0 coupe (NA)
You can't buy happiness, but you can buy car parts which is kind of the same thing.
Old 07-13-2015, 05:21 AM
cycling has-been
bkreigsr's Avatar
Whatever you end up using - stay away from the one's that bolt to the strut top. (Weltmeister). The strut top needs to move as the suspension cycles. Most of the good one's now bolt to the camber plate bolts.
Bill K
Old 07-13-2015, 10:28 AM
Will you be auto-xing or tracking the car? If not, you will be giving up useful trunk space for almost no noticeable handling gain.
Old 07-13-2015, 10:39 AM
sugarwood's Avatar
Bill K
I think I have this. Can you clarify the flaw?
I was thinking of removing it, b/c it gets in the way, and I don't really drive aggressively. Is this easy to remove?
I'm mot sure what OEM looks like, so it's not clear if I just remove the 3 bolts, and then replace them without the bar?
Is there any adjustment that will be lost? (like an alignment)
1986 Bosch Icon Wipers coupe.
Old 07-13-2015, 11:24 AM
Jack the car up off the front wheels, and make sure the lower left camber plate bolt (in your picture) is tight. Then loosen the strut bar adjustment lock nuts and twist the bar so that it is out of tension or compression, and then remove the two camber plate bolts and larger shock nut holding the bar "anchor plate" to the car. After removing the strut bar assembly, retighten the same two bolts and shock nut. Point is, the one tight camber plate bolt should be able to hold the camber plate in position through out this process.
Old 07-13-2015, 12:35 PM
cycling has-been
bkreigsr's Avatar
sugarwood;8708578]I think I have this. Can you clarify the flaw?
The top of then shock actually pivots on the camber plate - this is by design.
Without the brace on, measure the distance from the inside fender lip to the center of the shock bolt. Jack the car up to raise the wheel almost off the floor. - measure again - two different numbers! Think of it, as the bottom of the strut raises and lowers on the same plane, the top of the shock must move. That's why Tarett and others (ER) make a monoball configuration. The stock camber plate uses a rubber biscuit to control this movement, the monoball eliminates all the slop inherent in the factory bisquit.
Bill K
Old 07-13-2015, 01:16 PM
look into the rebel s racing strut bar, installation is swapping two bolts with longer ones.
pardon the mess
'74 911 ('73 RSR "tribute") - Backdate project that sort of went off the deep end.
http://forums.pelicanparts.com/porsche-911-technical-forum/996223-bergos-1974-911-backdate.html
Old 07-13-2015, 01:45 PM
sugarwood's Avatar
I'm an idiot. I'm not sure which is the "lower" camber plate bolt? (Frankly, I don't even know what a "camber plate" is, or what it does)
Can you restate your directions using these numbers?
Pretend you're talking to an 8 year old who has never seen a suspension, but knows how to use tools.
Bill K
Thanks for trying, but suspensions are a blind spot, so this explanation is lost upon me.
Bottom line: Should I remove my Weltmeister strut bar?
Does it actually do anything beneficial?
Old 07-13-2015, 02:40 PM
cycling has-been
bkreigsr's Avatar
Yes. It keeps the strut towers from flexing towards or away from each other.
Old 07-13-2015, 08:27 PM
Sending PM.
Old 07-14-2015, 08:16 AM
GOM (Grumpy Old Man)
Busta Rib's Avatar
I got mine from Automotion. It is a CF piece and costs about $200.
Instagram: @3pedalposse
Old 07-14-2015, 08:42 AM
I've fitted turbo track rod ends and new bushes. Also replaced strut top camber plates.
The strut brace is really just to finish off the front suspension geometry and to keep
The strength whilst pushing hard.
Not too bothered about space in the trunk!
Been advised not to fit strut top mounting units.
I do like the black strut brace! Is it carbon or just carbon look? Busta rib
Old 07-14-2015, 01:43 PM
