-   -   Removing hood crest (http://forums.pelicanparts.com/porsche-911-technical-forum/874439-removing-hood-crest.html)
BeeMaster 07-12-2015 09:39 AM
Removing hood crest
I am trying to remove the hood crest. I look up the two holes there are not any nuts
But there are these small rectangular plates up there. Has anyone seen this before an d what is the best way to remove them? Thanks I read project 73 in Wayne's book but it doesn't talk about anything that looks like this.
vintagecarlover 07-12-2015 09:42 AM
Should be 8mm speed nuts. Either was turn counter clockwise with needle nose
BeeMaster 07-12-2015 09:51 AM
Sorry I have a 76 targa 911 s
Joe Bob 07-12-2015 10:54 AM
Two studs with 8mm speed nuts is standard.....but you never know what previous owners will do or have done. Pics are equal to a 1,000 words.
BeeMaster 07-12-2015 12:20 PM
Sorry i had a hard time taking the picture.http://forums.pelicanparts.com/uploa...1436732444.jpg
BeeMaster 07-12-2015 12:22 PM
http://forums.pelicanparts.com/uploa...1436732514.jpg
Joe Bob 07-12-2015 12:31 PM
No nuts.....tap them out. Use a wooden dowel, placeit on the stud, tap with a hammer.....
964TargaC2 07-12-2015 03:02 PM
Wooden dowel is for wheel center caps
There are non factory speed clips on this one try a needle nose plier or a pcb board hook to get them off..
Joe Bob 07-12-2015 03:09 PM
Looks to me like rubber snubbies w/o speed nuts. No nuts, tap it out....I still recommend a wooden dowel. SMALL one, a 2 inch dowel is for the Fuchs caps. Better pic w/o the rubber and I may change my mind.
The OP should be smart enuff to figure out that nuts won't pound thru.
BeeMaster 07-15-2015 03:56 PM
Thanks I will try that carefully. Sorry for the slow response my I pad went down after
Asking sorry thanks again.
BeeMaster 07-17-2015 08:24 AM
Tapping it with a dowl and wooden mallet gentally got it off. I tried a long needle nose
But once up there it could not open thanks for the help.
