Banned
redducati750's Avatar
Send a message via AIM to redducati750
3.0 cylinders and pistons swap
can 3.0 cylinders and pistons be used on a 2.2? what whould this swap accomplish and how hard would it be
Old 11-13-2002, 09:34 PM
Warren Hall Student
Bobboloo's Avatar
No. The head stud spacing is different.
The largest P+C combo is 2.9 available from Mahle for about $2500. Spigots will need to be cut out to 97mm? I forget the dimension but it is the same as a 2.7 case.
An alternative is to bore 2.7L 90mm cylinders out to 92mm replate and add JE 92mm pistons for a 2.8 liter motor. The used cylinders can be picked up for about a $100. The JE's are a $1000. You can call US Chrome to price the boring and plating.
Old 11-13-2002, 11:27 PM
