'80 SC injection question
Hi all,
I'm new here, and since 3 months the happy owner of my first porsche. It's a 1980 SC coupe (American Version) But i have some questions. I've got some problems starting the car, benzine pump is running, but it starts and dies after a couple of seconds. After a few tries mostly the engine starts to run and to keep it up you have to keep the throttle up a minute or so. Then when i go out for a drive, when pushing the throttle it produces constant backfires. I think the problem is the K-tronic. But what do you guys think? Should i look first at other things before looking to the K-tronic? I don't know how long the car hasn't been driven. I've bought at from a merchant who bought the car in America, so I think the car has been underway to EU for a couple of months. I hope someone can help me! Regards! Wout |
Welcome to Pelican. Is it backfiring through the intake or the exhaust? Also, when the engine is warm and at idle, remove the oil cap. Does the engine RPM decrease or stay the same?
Thnx,
it is backfiring through the intake I think. I have to check the last thing you mentioned. Why is that? |
Sounds like a Jetronic issue, as you suspect.
The Jetronic brain is powered by the same fuse that runs the interior lights (dome lights). Do they work? The brain and power relay are under the passenger seat, remove the seat and check that they are there, intact, and have power. |
Backfiring through the intake suggests a vacuum leak. Also, opening the oil cap while the car is idling compromises the vacuum of the system thus leaning the air fuel mixture. The idle should drop after the oil cap is removed.
Right now I am leaning towards Pazuzu's thoughts. This is because Wout indicates constant backfires. If they are intake backfires, I am betting the freq valve is not getting juice. Could be as simple as the fuse in the front trunk. |
The problem could also be caused by shorting plug wires. An easy test is to start the car at night in a relatively dark area and look at the engine while its running. If the wires are bad, you will see little lightning bolts going from the wires to the closest ground. This may not be the answer, but the test is easy and free!
Welcome to Pelican. Please post pictures- it's a tradition.
If the car is just off the boat and still has the old gasoline (benzene) in the tank, that may be creating your problems. If you want to search the forums, your fuel injection system is usually called "CIS" (Continuous injection system) by most on the board. There are many great resources. |
Thnx for the advice guys!
I will have a look at each of the suggestions you tell! There's already new gasoline in the tank, also a new air filter and oil. here are some pictures of the car. Didn't know it was tradition. http://images.tapatalk-cdn.com/15/04...8700bffefb.jpg http://i62.tinypic.com/efjeyw.jpg |
Maybe a dumb question (i"m not that technical educated, but i'm happy to learn it).
How do I know if these fuses are working? Do i have to read them out with a multimeter or something? The box is there, I removed the passenger seat this weekend because it wasn't flipping when pressing the handle. And i found it funny that there was an electronical box underneat it. i thought the SC was the last 911 without ECU. |
Starting in 1980, there are two components of the Lambda system under the passenger seat. One is the Jetronic box, one is the oxygen sensor relay.
The Lambda system uses the output from the oxygen sensor (in the exhaust gas stream) to give the correct air-fuel ratio by adjusting the amount of fuel injected. The system is not active until the engine warms up, so if your car starts its poor running a few minutes after cold starting, replacing the oxygen sensor relay is a good (and simple, and cheap!) first step. I had trouble with my oxygen sensor relay not long after I got the car, and replacing it made a huge difference! I assume BE means Belgium; if so where specifically are you? Will you be going to the Spa 24? Dru |
Is this the same fuse as Pazuzu is talking about?
As he is talking about the brain fuse? I'm getting really confused about all this information :( Yes with BE I mean Belgium, I'm living near Ypres. Spa 24 hours i'm going to miss this year, because of renovations on the house ;-) And work on the car :D |
Luggage compartment fuse box............
Wout, Get familiarize with the fuse panel in the luggage compartment (front). There are 21 electrical fuses (8 + 10 + 3). Starting from the front of the car, you should find the first section with 8 fuses, second with 10 fuses, and lastly 3 fuses (total = 21). Get a reference manual like Bentley for SC and that would help you get familiarized quickly about your car. Fuse #18 is the circuit that supplies power to the FV relay, courtesy light, clock, and glove compartment light. Some people call this relay as OXS or ECU relay. The fact is that both oxygen sensor and ECU don't need a relay but the FV (frequency valve) does. Whatever name we use to call this particular CIS component is irrelevant at this point as long as we understand each other. Get the engine to warm up close to engine operating temperature. And perform these simple tests: a). While the engine is idling between 800 - 900 rpm consistently (steady), remove the oil cap and observe any noticeable idle speed change. b). Next, disconnect or remove the relay (FV, OXS, ECU, etc.) under the seat. Observe for any change in the idle speed behavior like rough idling. Repeat this test a couple of times. c). Is there power at the plug connector to the relay when engine is idling? d). Locate the FV behind the motor and feel if it is vibrating or pulsating when the engine is running. You could do this test without running the engine if you know how to test run the FP (fuel pump). Keep us posted. Tony |
One reason that I mentioned the OSX relay is because those symptoms are 100% what I found on the two times that I had problems (once the fuse had blown, once the relay died). You could get the engine started, sometimes with some extra throttle while cranking, it would idle but barely, and you could theoretically drive it down the street with full throttle, but it would be backfiring and bucking continuously and violently.
So, there is 3 things in that "system" that could fail suddenly (or because of a bumpy trip across the ocean). The fuse under the hood (#18 per boyt911sc), the relay itself that is under the seat (the small cube, not the bigger controller), or the controller itself (unlikely, I think that would kill the engine completely). also could be wiring, etc. Quick fuse check is: Do the dome light and/or glove compartment light work? If so, the fuse is good. If not, the fuse is bad, problem solved Quick relay check: Remove relay, do symptoms become much much worse? If no, then relay is broken, replace. If yes, then move on. I assume that the car didn't get washed with seawater or anything, since that relay sits on the floorboard, it's susceptible to minor flooding. |
Thanks guys, I've just got out of the garage without reading your tips.
I was feeling a little stupid because I was looking at the box under the passenger seat. But couldn't find any fuse on the box. Stupid stupid me! They are all in the front. Here's a picture of the box under the passenger seat. So the small one rightabove, with the wiring is the relay? If I'm correct? What is the bigger box for? http://i62.tinypic.com/28qr9u0.jpg Now I'm going back to the garage to check the inner lights and check fuse number 18. |
Fuse # 18 is working: glove comp. lights are working...
Tomorrow I'm gone check it with the engine running. I'm just afraid that the engine won't start and that I will flood it because of trying to much. One thing I noticed when turning the key to check the lights and fuse is that the fuel pump is working constantly. Doesn't this shut down after a couple of seconds? |
Fuel pump
Question- how do you know the fuel pump is running? If you are hearing a high-pitched whine from the back of the car, that is the Capacitative Discharge Ignition (CDI) box, not the fuel pump. The fuel pump is under the front of the car, near the steering rack. My family and I have been to Ypres several times; beautiful town, sobering history. We also go to Malmedy on a regular basis to replenish our food (everyone), beer (me) and chocolate (her) supplies. I'll be going to the Spa 24 with my 2 sons and some other friends. Hopefully we'll see you another time! |
It's a high pitching noice, but it's from the front of the car I think.
I think they told me that was the noice of the fuel pump when you turn your key on, but not start the engine!? @ RDM: there is indeed a possibility that we can meet one time. As I go also on regular base. But I go more when there are Porsche related or historic events on Spa or sometimes to the Nurburgring. |
You are receiving a lot of information. Just be patient. No one expects you to understand the system immediately. Lambda relay........ Here is a video that I made several years ago unplugging the Lambda relay. Listen to my car. It drops down in rpm and "pops" when I give it gas from intake backfires. Maybe this is close to the problem you have? <iframe width="420" height="315" src="https://www.youtube.com/embed/5tdpCYyvqSc" frameborder="0" allowfullscreen></iframe> |
Is it harmfull to let the engine run when the car stands still?
I may not legally to drive on the road, as I didn't have the car MOT/TUV (don't know how to call it in English) because of the problem with the backfire i will wait to go there. So for the test where you need a warm engine, i would turn it on and wait a few moments. If this isn't harmfull for the engine. |
Only if you did it all the time. For troubleshooting purposes it's okay.
Ok,
i'm gonna try to start the car tonight and see if there is a difference when pulling out the relay. And also try to film the process, so there can be a good judgment |
Trouble shooting.........
Hi guys SmileWavy,
I did my homework tonight :) but I'm not wiser after the test. 1. Trying to start up the engine, trying to crank after 5 times didn't start or barely started the engine. 2. Removing the air filter and pressed the plate in the injection system, then cranking, and immediatly the engine started, but no trouble with shooting. Here you see a movie of the engine turning. View My Video 3. Once the engine was stable, I removed the oil fill cap. Also no difference. See video. View My Video 4. The last test was made removing the relay. Also when removing the relay nothing happened. Turning back on the relay made the engine stall. See the video. View My Video 5. I found it really strange that the engine was more normal then otherwise. So I turned back on the engine and immediatly it was back shooting, backfiring like otherwise. But damn I didn't made a video now. So I turned it off. Then I filmed again, now I'm in the car and start the engine up. You'll see that it up banging and popping. So then I pull out the relay and nothing changes. I put back on the relay and the engine stalls again. Then I forgot to shut down the camera. Sorry for the long video. But I'm no video expert and editing :D View My Video Hopefully someone finds a clue in the explanation. Thnx! |
Nobody? :(
Backfiring..........
That sounds to me like it is backfiring thru the exhaust. That would typically be indicative of a system that is running much too rich. At this point, I believe that you need to either get a set of test gauges and check the fuel pressures and use an exhaust analyzer to check the CO reading from the exhaust or take it to a shop to have the tests done. The information on how to do these tests is available on this forum, just do a search. The air bleed adjustment screw is just above and to the right of the throttle linkage in the side of the airbox. The fuel enrichment screw is located just to the right of the fuel distributor. It will require a long 3mm allen wrench to make enrichment adjustments. The screw is down in a hole and can be difficult to find. Turning the screw in (clockwise from top) makes the adjustment richer and out (counter clockwise from top) makes it leaner. Good luck and keep us informed of your progress!
But how can you tell the difference?
Sorry for all the questions, I'm a scientist, so I like that everything I know, happens for a reason :D If it's running to rich, Is this why it mostly starts when opening the airfilter box? So it sucks more air? So when pumping more fuel, you have more air needed to have the correct mixture? |
Air fuel ratios.......
The theoretical ideal air/fuel ratio is 14.7/1. That may be a bit too lean for some engines to run properly so carburetors and fuel injection systems tend to run a little richer, closer to 14/1. Under hard acceleration, the mixture needs to be richer, maybe down in the upper 12 or low 13 range to keep from burning a valve or piston. When you open the air filter box, do you pull up on the plate or push down? Pulling up will allow more air to the intake temporarily leaning the mixture, pushing down should make the a/f ratio temporarily richer. At this point, before you start turning adjustment knobs, etc, you need to know where the fuel injection is set now. One thing you can do, is to find the air bleed screw/knob on the left side of the air box just above the throttle linkage. Turn it all the way closed while counting the turns. Then, back it out about 3 turns. That should be close to the correct setting for your engine. The fact that the engine did not change rpms when you removed the oil cap indicates to me that the air bleed screw is too open. Normally, when you remove the oil cap, the engine will choke down and quit running. Since your engine did not do that, it indicates that an excessive amount of air is getting into the box somewhere else. I hope this helps. Try adjusting the air bleed screw and then restart the engine. Let us know what happens! |
Sounds like electrics,start with plugs,cap and rotor as they are relatively cheap,if it runs better but not great check the leads and replace if required.
Is your engine timing correct? You need to get the car in the best state of ignition tune before you look @ the fuel injection,this is a mistake many make and just blame that. You might want to change your fuel filter also,I always give a new purchase a service,hard to believe some past owners have done this and that,when YOU do it you really know then,good luck. |
@ Porschetub: When I've purchased the car, they told me they already had new oil, oilfiters en spark plugs. And indeed everything looks fine. So I think I can trust them on that.
Don't know what the sate of ignition tune. Is it something you can do easily yourself? Just thinking next to the to rich state of the car, sometimes when you push the throttle it feels like the car is somewhat coming behind in its reaction and sometimes the rpm stay to high when releasing the throttle. Then dropping again to stable rpms. i've experencied this when driving the car home from the garage. When I did open the air box I pulled the plate up! I didn't know that you can pull it down. As i thought in the box it's always at the lowest point. |
Problem is found.
I went with the car to an OPC to have a diagnose. They found out I have broken cylinder head stud. That's why the engine sounds like it's backfiring. |
Oh no. I'm sorry to hear that. You didn't get a chance to have some driving fun with your car. A rebuild is in its future.
[QUOTE=RDM;8708992]Welcome to Pelican. Please post pictures- it's a tradition.
" its a tradition " This must be new as Ive never seen this in all the years of surfing this site. :) |
Wout,
A broken head stud won't account for all the symptoms you describe. However, I've had that experience, and learned a lot. Are you considering fixing it yourself? It is do-able. And while you're doing it, you have much better access to all the other things that cause these kinds of problems. Here's the thread describing my head stud adventure, There are many others! http://forums.pelicanparts.com/porsche-911-technical-forum/789817-start-maintenance-end-disaster-opportunity.html |
I am surprised one broken stud would cause that.
Problems with the bad running is disappeared without any reason.
After i posted the video, I haven't touched the car for a month. until i contacted the OPC. I had to wash the car before they came to collect it. And with the first turn of the key the engine started. Since then no problem with difficult start. The technician only reset the fuel/oxygen ratio and it starts smoothly. Only problem is the studs you here in the engine when pushing the throttle. So no more driving or very very calm if necessary |
| All times are GMT -8. The time now is 11:16 PM. |
