AKA SportsCarFan
Need tire size confirmaton ASAP
Hi guys. I was preparing my car for a tour & I noticed a screw in 1 of my rear tires. The tire is a Bridgestone RE11 225-50-16. I am leaving Wednesday evening, so I'm scrambling!
Tire Rack says they can have tires to my installer Wednesday, which would work. But they don't have 225s in stock. I was thinking of switching to a 245-45-16, & they do have them in stock. Before I order I want to confirm with the 911 brain-trust that they will fit fine on Fuchs 16x8 wheels. Please confirm! Thanks. P.S. - I tried to search but wasn't coming up with the correct results, so in the interest of time I started a new post.
Doug Miller 1988 Guards Red Carrera Last edited by FastCarFan; 07-14-2015 at 03:46 AM.. |
yes, 245 45 16 RE11s definitely fit on 8x16 Fuchs. Had them on my M491. Excellent tire, fit and looked great on the wheel.
Tru6 Restoration & Design |
AKA SportsCarFan
Thanks for the quick reply. I'm literally about to "check out" on Tire Rack. I was almost positive they would, but wanted to be sure.
You guys are the best...especially Shaun!
Doug Miller 1988 Guards Red Carrera |
The best part of having 8s in the rear is you can use 245s when they are available and 225s when they aren't.
Good luck Doug!
