-   -   Timing Chain Problem Seeking Help (http://forums.pelicanparts.com/porsche-911-technical-forum/874688-timing-chain-problem-seeking-help.html)
JDC911 07-13-2015 10:34 PM
I am in the process of replacing the left timing chain because it is extremely stretched out. The car is a 1985 911 Carrera and has a lot of noise coming from the left timing cover. I set the engine at TDC and neither the distributor or the cam seems to be a the correct position (from what I have read). The crank pulley did not have Z1 stamped on it ,just two marks about an inch apart. I put a screw driver in the spark plug whole to determine that cylinder 1 was at TDC and choose the mark on the crank pulley off this. I realize that I am going to have to re-time the cams but wonder why the distributor is about an half inch to the right of the mark on the housing and the number 930 on the cam is pointed at 10.00 o'clock instead of 12.Has anybody seen this situation before and have any ideas about what is wrong and how to fix it ?I posted some pictures. Thanks for any help , John http://forums.pelicanparts.com/uploa...1436852057.jpg
JDC911 07-13-2015 10:36 PM
Here is a picture of the distributor.http://forums.pelicanparts.com/uploa...1436852204.jpg
JDC911 07-13-2015 10:51 PM
last picture crank pulleyhttp://forums.pelicanparts.com/uploa...1436853113.jpg
gtc 07-14-2015 09:20 AM
Looks like you might be a tooth off on the distributor drive gear. Usually at TDC the rotor will be a bit to the left of the mark, like this:
http://forums.pelicanparts.com/uploa...1252764924.jpg
Flat6pac 07-14-2015 10:05 AM
This is a second post on the same items telling you the same things
Bruce
eastbay 07-14-2015 02:58 PM
that is one wasted sprocket, imagine the one on the intermediate shaft also looks the about the same
