-   -   Humbled by 78 SC again... Where does this stuff go? (http://forums.pelicanparts.com/porsche-911-technical-forum/874821-humbled-78-sc-again-where-does-stuff-go.html)
cpcooper 07-14-2015 08:22 PM
Completed a fairly extensive paint job and thought I'd freshen up the engine a bit. Can't find a home for two brackets and three chingaderises. Somewhere around the alternator/fan? Any help greatly appreciated. http://forums.pelicanparts.com/uploa...1436930514.jpg
tirwin 07-14-2015 08:44 PM
The 3 silver things on the left are bracket that attach to the top of the fan shroud. The heater hose that comes out of the right bank of heat exchangers lays on top of them and there are clamps that go around the hose that hold the hose to the bracket.
Pretty sure the top right bracket goes on the back left and holds up part of the CIS stuff. I think it sits in the throttle bellcrank.
timmy2 07-14-2015 08:49 PM
Bottom piece is the support structure for the blower motor. The motor sits in the curved part and is held by a strap.
Top right bolts to back of air box rubber isolator stud and to one of the bellcrank bolts.
Dr J 07-14-2015 08:50 PM
1 The large black piece on the lower right goes in the engine compartment to hold the heater blower on the drivers side. It bolts to the #2-3 intake manifold.
Mine looks different because i cut the top of the bracket off.
http://forums.pelicanparts.com/uploa...1436932094.jpg
The upper right black piece looks like the CIS airbox to engine bracket. It connects to a bolt near the center of the engine farthest from the bumper to a spot in the cis box through a rubber buffer.
Dr J 07-14-2015 08:56 PM
Pic of upper part.
http://forums.pelicanparts.com/uploa...1436932525.jpg
Near the cold start valve. Again ignore the non-stock components on my metal airbox. :)
cpcooper 07-14-2015 09:01 PM
Thank you, thank you!
