-   -   Installing 95 993 3.6 into 82sc (http://forums.pelicanparts.com/porsche-911-technical-forum/875028-installing-95-993-3-6-into-82sc.html)
axvel 07-16-2015 10:45 AM
Came here to Pelican a long time ago. And always read all the posts regarding 3.6 swaps. And finally got mine. I bought the car in 2008 and never got to it. Family, Kid, dogs, another kid, life.
So i bought a 993 engine and want to install it.
Have couple of questions.
Wiring Harness Adapter - this i get
Flywheel - Flywheel came with my motor, do i need to get specific one for 915 transmission
Throttle Cable - this i get
Single Pulley - this i don't understand. Does the fan on 993 has a clutch? I was planning to leave A/C Compressor and have a working A/C
Power Steering Block Off - I also do not understand this. Is it some hydraulic thing that needs to be plugged?
Cold Air Intake
3.0/3.2 Engine Tins
3.0/3.2 Pulley/Engine Console
External Oil Cooler install. I have 2 oil coolers in the front bumper, can i just route the hose to them?
Do i leave the oil tank on the side in the quarter panel as well?
http://i133.photobucket.com/albums/q...psby2fmu8b.jpg
http://i133.photobucket.com/albums/q...psndfomey8.jpg
http://i133.photobucket.com/albums/q...ps5avutr0u.jpg
http://i133.photobucket.com/albums/q...psau8lbjog.jpg
http://i133.photobucket.com/albums/q...psatk7yygz.jpg
http://i133.photobucket.com/albums/q...pslrijbvek.jpg
http://i133.photobucket.com/albums/q...psrwyijbyg.jpg
http://i133.photobucket.com/albums/q...ps92xf25u9.jpg
http://i133.photobucket.com/albums/q...psrrloaqst.jpg
http://i133.photobucket.com/albums/q...ps3wzwegig.jpg
axvel 07-16-2015 10:51 AM
The car was a stripped insurance sale when i got it.
http://i133.photobucket.com/albums/q...psoaa97gjw.png
http://i133.photobucket.com/albums/q...psvyshjfkk.png
http://i133.photobucket.com/albums/q...ps3jy6p6iq.png
http://i133.photobucket.com/albums/q...psad78501d.jpg
http://i133.photobucket.com/albums/q...ps7103c157.jpg
Albert356 07-16-2015 10:55 AM
The excitement builds! Good luck with the build keep us posted on how its going!
axvel 07-16-2015 11:04 AM
Will do, thanks!
Bill Verburg 07-16-2015 12:39 PM
Cold Air Intake
3.0/3.2 Engine Tins
Assuming the use of a 915 trans you will need a flywheel that is compatible w/ the 915 225mm clutch, the stock 993 uses a 240mm which is incompatible. A Sachs 915 Sport clutch or a Kennedy 915 clutch is a good option, flywheel can be purchased frpm Dr Timmons or Patrick Motorsports
The stock 993 fan pulley has two independently operating sheaves, The RS & Cup ran a single splined sheave on the fan and depending on whether AC was retained or not a single or dual sheave crack pulley. To retain AC run the stock 3 sheave w/ a bare sheave or run the RS mit AC option dual sheave. W/ or w/o AC you can run the single pulley fan. The only downside is that the alternator runs a little slower.
Since he power steering is not used on a 911 t/p the cam driven p/s pump on the passenger side is removed, this leaves a hole that is best covered by a little plate. Timmons, Patrick and Rothsport all have these or make your own out of a sheet of tin
don't worry about a cold air intake, there is a snorkle line addition to the stock air box intake that can be purchased but it is not at all necessary, the cooling fan keeps engine bay temps near ambient while it is running fast.
most of us retain the 2nd engine mounted oil filter and run several variations on front cooling, for track use you need a ton of cooling and a large valance mount is a minimum, add one or two fender mounts for additional cooling, for street use a med/lrg valance mount or maybe 2 fender mounts is fine
Most likely but not necessarily you will want to ditch the engine mounted cabin air fan and duct heat w/ an RS tube
axvel 07-16-2015 01:11 PM
Bill thank you for your input. Greatly appreciated.
From this list is there anything that i need to add to it, or something i can do without?
http://i133.photobucket.com/albums/q...pssxn4tt5c.png
http://i133.photobucket.com/albums/q...psjomehp7k.png
0396 07-16-2015 02:16 PM
Your 3.6 looks very clean. Good luck with your build.
Bergo 07-16-2015 02:39 PM
mind if I ask what the 3.6 ran you?
Bill Verburg 07-16-2015 04:12 PM
you will need
camshaft block off cover is needed
the oil pressure sender from you SC might work, if not get the pressure sender, the 993 sender gives reading too high same w/oil pressure sender
studs to mount the trans are needed
oil feed adapter(993 version) is needed
KEP clutch set is recommended
the oil lines are needed unless you already changed the stock SC ones
single belt fan drive is recommended
the starter ring gear is needed
secondary injection block off if deleting SAI, recommended
for track use the catch can can be desireable
wire harness conversion is needed
Dpmulvan 07-16-2015 04:28 PM
Looks like a nice project good luck!!
redturbo911 07-16-2015 05:28 PM
Looking good
axvel 07-17-2015 10:30 AM
Bill, thank you for your help. Will be placing the order shortly
Originally Posted by Bill Verburg (Post 8713674)
you will need
axvel 07-17-2015 01:17 PM
Order Placed with Patrick, Now patiently waiting. :D
http://i133.photobucket.com/albums/q...psid5jipye.png
http://i133.photobucket.com/albums/q...psebb5fb44.png
Albert356 07-17-2015 01:43 PM
Patrick Motorsports will be your best friends for this conversion haha.
axvel 07-17-2015 01:56 PM
I really hope so :D
BoxsterGT 07-20-2015 07:50 AM
I noticed that no-one has commented on fuel lines for this 3.6 engine swap.
The fuel system in the SC uses M14 Fittings & Hose while the 3.6 993 motor uses M16 fittings throughout. If you keep the stock Fuel Filter, I have the correct Metric fittings & E-85 rated "Direct Connect" Hoses to make this job an easy one.........
http://forums.pelicanparts.com/uploa...1437403058.jpg
http://forums.pelicanparts.com/uploa...1437403157.jpg
For information on these components or for any other Metric Fuel or Oil Hose questions, please email me.
Len at Autosportengineering dot com
0396 07-20-2015 08:02 AM
Len,
You Da Man. .when I attempt this conversion. I know another source to contact.
To the original poster, any further up dates?
Enjoy your week
axvel 07-20-2015 09:18 AM
Len thank you, i think in the order above i ordered fuel conversion as well. I will be changing the filter and the fuel pump. But if i will ran into a problem i will contact you:)
axvel 07-20-2015 09:46 AM
So weekend went well. Was able to go Autocrossing and get some work done on the car.
http://i133.photobucket.com/albums/q...ps4rfazys4.jpg
http://i133.photobucket.com/albums/q...psmtvqcoua.jpg
http://i133.photobucket.com/albums/q...pshqvociae.jpg
http://i133.photobucket.com/albums/q...psvtiopqu6.jpg
http://i133.photobucket.com/albums/q...psn2xcoroi.jpg
http://i133.photobucket.com/albums/q...psjvgwatxe.jpg
Jack Olsen 07-20-2015 11:37 AM
Here are some inspirational sounds for you. A 1995 993 in an early tub.
https://youtu.be/t7fASUvUIxY
