Humidity problem
Hi,
I have a 911 1986 , 3.2 liters. When the air humidity is above 90 %, my car has the difficulty to start and the engine stall. I cleaned the air flow damper last april. I will change the wires plug, distributor cap. I have the same problem as Jim Garfield. Thank Roger |
Check the connections to the fuel injectors as well. I had a problem for a short time that the car did not run right after I washed it. I kept playing with the ignition stuff and it turned out to be the one injector connector that was not solid.
Glen 49 Year member of the Porsche Club of America 1985 911 Carrera; 2017 Macan 1986 El Camino with Fuel Injected 350 Crate Engine My Motto: I will never be too old to have a happy childhood! |
Humidity problem
Hi,
I found that my wire connected to the coil was oxidized. I brushed it and it is OK. I will change the coil and the wire. Also, a new cap and rotor will install soon. Roger |
Keep your old coil as a spare.
The new Bosch coils are crap. Often no good right from the box.
I need to buy a brand new wire coil for my 3.2 liters. Where i can buy one. The problem is: i must buy the complete wire set. I need only the coil wire. My 911 is not the turbo model.
Roger |
What do you thing about the Bosch wire set ? Is it better then Beru wire ?
Roger |
Beru's are good. I have Magnecore but I've never heard anything negative about Beru's.
