-   -   Turn signals and hazard not working on 76 (http://forums.pelicanparts.com/porsche-911-technical-forum/875913-turn-signals-hazard-not-working-76-a.html)
christiandk 07-23-2015 02:52 AM
Hi guys,
I have replaced the relay behind the oil guage and checked the fused - not that. No melted sockets either.
Any idea what to check next?
Thanks,
Christian
RD911T 07-23-2015 05:57 AM
Take the fuses out and clean them and replace. Start checking for power and continuity on each wire in the system. http://members.rennlist.org/911pcars/WiringDiag.htm Go to this link to find a wiring diagram for your 76. I emailed a copy to Staples and had it blown up and laminated
fintstone 07-23-2015 07:04 AM
One easy thing to check is the black connectors that plug into the firewall just above your feet to ensure they are seated well. Sometime the one that goes to the turn signal comes unplugged.
christiandk 07-23-2015 09:48 AM
Thanks guys,
Flint, you nailed it. Blink blink blink....thank you so much!
fintstone 07-23-2015 02:04 PM
No problem. Glad to help.
