993 engine bottom end strength........
Does anyone know if a 1996 993 engine will handle 3.8 P&C's
without the possibility of damage? I have heard that the rod bolts and crank are weaker on the 993's VS. the 964 engines. I am considering the upgrade. Also for those that inquired about the 97 Turbo S engine and tranny, it is sold. I hated to let it go but I was told it would have required major mods all around for fitting it in an early 911. |
Isn't the 993RS a 3.8L?
993 and 993RS use the same crank. There are several different versions of pistons/cylinders/valves/heads/intake manifolds.
Re: 993 engine bottom end strength........
The 964 crank is supposed to be a little more robust than the 993 for racing purposes as well, but I wouldn't worry about a 993 crank if you change out the rod bolts. TT |
| All times are GMT -8. The time now is 09:17 PM. |
