-   -   Spark Plug gap with MSD (http://forums.pelicanparts.com/porsche-911-technical-forum/876191-spark-plug-gap-msd.html)
Norm01 07-24-2015 03:04 PM
This is on a 68S 2.0 weber carb engine. Using NGK BPR8ES with an MSD ignition. values for plug gap range widely from the Porsche manual which ranges from .012" to .018 for a factory ignition system to MSD which says .050" to .060 and from Wayne Dempsey which states .050" to .058". What would be recommended, can I really run .050" gap.
mreid 07-24-2015 03:25 PM
You didn't mention compression ratio, but I've found .045" to be about best.
BURN-BROS 07-24-2015 03:31 PM
.045 is about the max you want to run with a distributor. Gaps above this starts to stress the cap/rotor and shorten their lifespans.
Bob Kontak 07-24-2015 04:27 PM
As well as find every short coming in your wires and wire looming configuration.
